3UZ-FE starter in an 1UZ-FE car?
I have a 1995 SC400. I'm doing a starter job. My car was built 4/95. There are two possible starters for the car, up to 5/95 and post 5/95. I got the pre-5/95 starter and it seems to be hitting the flywheel. I can not rotate the flywheel w/ the starter installed. Someone mentioned using a starter for a 3UZ-FE car. Anyone tried this?
Dude,
Toyota is well known for including older generation parts when transitioning into the next model variant so I would try a post 5/95 starter.
Turns out that I had the correct starter (part #), but something was wrong with its spec. I swapped the starter for another of the same one and it fit perfect. No binding issues. I gotta chalk this one up to a bum rebuilt part.
Thanx.
JD
I have the same year and model as you, and also need to replace the starter assembly. And you're right-there are 2 different starters. How did you determine when your car was built? I put in my year/model on LexusPartsNow and it showed 2 options. I put in my VIN and it gave me this: Lexus Part No.: 28160-54071. Is this correct, or did you use a different PN for the 3UZ-FE? And where did you get it if you don't mind sharing?
Thanx.
JD
Thanx.
JD
SCGIRL400
SC- 1st Gen (1992-2000)
08-01-11 02:26 PM
