sc400 not cranking, have fuel, and full battery
hi,
So It seems my sc400 is not starting. I had a new key made, and the drivers door handle was broken, so initially I thought it was the immobilizer. Ive locked and unlocked the drivers door many times, disconnected the battery (full).
there seems to be no click sound, Can anyone confirm the starter relay is green relay in the engine fuse box? I am going to replace this.
Does it sound like a starter issue? I just dont want to pull it all off if its not. thanks!
hi,
Dude,
What error codes are you seeing, if any?
Dude,
It could very well be the starter/starter solenoid that is dead and needs to be replaced. Definitely check anything having to do with the starter and physically check all connections to rule out corroded/missing contacts.
Good luck
Harbinger
Performance & Maintenance
05-16-13 06:40 PM
