Mixing coolants
Old 05-29-15, 08:25 AM
Tabaka
Tabaka's Avatar
So I looked in the radiator and it's pink as it should be. A little bit of the coolant overflowed into the overflow bottle. Keep in mind that my friend only added the green crap to the overflow tank. So my idea is to take the overflow bottle off, and just pour that crap out, and add 50/50 toyota mix pink stuff. I believe I have half a gallon in my garage somewhere.
Not that I'm super lazy, but for a proper flush I'd have to buy a container that's relatively shallow to the ground that can hold two gallons of fluid, then jack up the car, unscrew the radiator drain plug, then flush everything out with water, then visit a toyota dealership somewhere and buy two gallons of Toyota premix crap, then fill the tank, flush properly, etc. And where the hell does a happy home owner "discard" old coolant fluid?
My buddy just cost me more money, and about two hours of time
Old 05-29-15, 09:46 AM
t2d2
t2d2's Avatar
We're generally considered [way] ahead of the game as far as recycling here, so maybe other areas don't have it, but we can put containers of car fluids out with our glass recycling every other week and it gets picked up as part of the regular service.
Old 05-29-15, 10:02 AM
Ali SC3
Ali SC3's Avatar
if its just mostly in the overflow then just unbolt that and pour it out and fill it with the right stuff or just water for now since its summer. you just dont want the overflow to go empty or you can get some air in the radiator.
if the radiator is still looking that red/pink color, then just empty the overflow and fill it with water for now, pour some concentrate in there later when you get a chance.
Old 05-29-15, 12:15 PM
eknine9
eknine9's Avatar
I wish I knew, when I flushed my radiator none of the autoshops would take it and there was only one large recycling plant in the area, and they wouldn't take it unless I got some piece of paper from my utility proving I lived within a certain area... So I just tossed it in the dumpster.
Not my finest hour, but I don't live there anymore, and when recycling toxic chemicals is too difficult for individuals it just ends up being dumped where it's not supposed to. I blame the city for my illegal dumping.
Old 06-05-15, 07:43 AM
Tabaka
Tabaka's Avatar
I found a small coolant leak under my car this morning. I haven't gotten around to flushing the radiator and coolant system as of yet. Don't worry, I haven't driven the car in a few weeks. However, it seems like I need a new lower radiator hose. The radiator is only a year or two old with minimal miles on it. I never replaced the hoses and they look trashed. So, it looks like I'll be completing an entire flush after all.
nparthi
05-29-23 11:41 AM
RX4UNME
RX - 3rd Gen (2010-2015)
03-13-18 04:02 PM
81corolla
RX - 1st Gen (1999-2003)
14
12-07-16 06:21 PM
ecfune
09-18-13 05:47 AM
element51
01-03-06 01:19 PM
Quick Reply: Mixing coolants
