ABS delete question.
Would like to delete the ABS on my 95 sc300. From during research I found out all I need is to run two lines from the Brake MC. One for the rear brakes (Already Teed off on the fire fire wall underaneath the MC) and another line and a 'T' fitting for the front brake lines.
Would I be able to use the existing hard lines and bend/manupulate them to work? Also, what size 'T' fitting do I need for the front hard lines?
how is there no way to do it? all the lines are so close together is it really not possible with T fittings?
Super Moderator
Go through my build thread, car with black themed engine bay has abs delete and just re used existing lines.
EDIT :
on this page you will see the existing lines I re-used.
https://www.clublexus.com/forums/bui...-toys-176.html
You can, I didn't want to spend money on lines that will be hidden anyway so I used existing lines. You just have to move them around (meaning correct length of line to the right place ) and be creative on bending them. I did it on my Red Mamba .
EDIT :
EDIT :
Just read through that page, beautiful work btw, but I can't seem to find what T fitting size you used.
I am getting different answers, but I stil do not know what size to use.
Super Moderator
for my case, I just took out the T-fitting on my parts SC that separates the left and right rear brake lines . It was more of a Y fitting actually. Well again, I didn't want to spend where I know I can use what I have. So I used that Y fitting to separate the two front break lines.
thank you
just buy both sizes and return the ones you don't need. m10x1.5 and m10x1.25, although I still believe its 1.5. anyways, I guess you can but it just looks messier than with the abs there in the first place, lines going everywhere. that's why I did mine the right way and made new lines for the front and just made a new short one for the rear brakes. make sure you remove all your wheel speed sensors too as they are only used for the abs system, since you are not using it anymore I suggest removing the wheel speed sensors, computer which is right under the glove box and whatever fuses and relays power it so the light doesn't stay on on the dashboard.
