Slew Of Problems(92 SC400)
Old 04-17-15, 06:03 AM
Durvelle27
Durvelle27's Avatar
Could the ECU cause transmission not to shift
Old 04-17-15, 06:14 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
The ECU will most definitely cause transmission issues. Most sc4 trans issues are the ECU.
Old 04-17-15, 06:27 AM
Durvelle27
Durvelle27's Avatar
Thanks. Searching around for a rebuilt or used ECU now.
Old 04-18-15, 02:56 PM
Durvelle27
Durvelle27's Avatar
After a much closer examination i found this damaged capacitor
Old 04-18-15, 05:08 PM
t2d2
t2d2's Avatar
Yeah, there's something going on near R133. Either it's leaking or was previously and the leakage wasn't cleaned up when replaced.
Old 04-18-15, 05:31 PM
Durvelle27
Durvelle27's Avatar
It has a hole in the side of it
Old 04-18-15, 09:45 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Then there is your answer. Most, if not all of your issues are linked to the ECU. Have it rebuilt. Buying used will not be as reliable. GL and post what you find!
Old 04-18-15, 10:12 PM
Durvelle27
Durvelle27's Avatar
A fellow forum member offered a ECU from a 94 SC400 that's in working condition. But any suggestions on a place that does rebuilds.
Also I noticed this today. Timing is now off but if I reset the car it goes back to normal.
Old 04-19-15, 08:11 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I used the 150 dollar eBay option it is was great service, Tanin electronics is cheaper. Never used them so cannot really recommend but from what I hear they have great service and quick turn around. GL
Old 04-19-15, 08:24 AM
Durvelle27
Durvelle27's Avatar
I'll give Tanin a try hopefully that fixes the problem and it's not actual boar damage.
Old 04-19-15, 09:45 PM
TaninAuto
Sponsor
TaninAuto's Avatar
Someone already replaced the capacitors in that ECU. Hopefully it can still be saved.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 04-20-15, 05:25 AM
Durvelle27
Durvelle27's Avatar
How could you tell
Old 04-30-15, 06:06 PM
Durvelle27
Durvelle27's Avatar
Really need help with my knock sensors guys. I replaced both with brand new sensors but I still get code 52 & 55. So my timing is being retarded pretty badly as car loses almost all power. A lot of people said it's the knock sensor harness but I can't find one anywhere. Is it possible to wire it myself ?
ECU has been rebuilt which fixed a lot of codes but these two.
Old 04-30-15, 06:09 PM
TaninAuto
Sponsor
TaninAuto's Avatar
This was just covered
https://www.clublexus.com/forums/per...ighting-2.html
__________________
262-456-4147
Old 04-30-15, 06:26 PM
Durvelle27
Durvelle27's Avatar
I don't see where exactly. I see one guy mentioned he fixed his with a custom RG58 wire but nothing more.
GhostDog88
04-12-17 08:15 PM
Jacob1010
SC- 1st Gen (1992-2000)
13
11-06-15 07:21 PM
Shelton400
06-12-15 08:17 PM
soneencris
32
04-14-14 03:48 PM
tpnotch420
07-29-08 04:59 AM
Quick Reply: Slew Of Problems(92 SC400)
