Domestic Injectors on GE
Old 02-27-15, 01:50 PM
RedMansSC3
RedMansSC3's Avatar
Default Domestic Injectors on GE
I have some 1200cc precision injectors and just want some clarification. They are 14mm, so will these fit the GE rails on driftmotion.com that state they are for 14mm denso style injectors?
Also do you have to drill the lower plenum for the injector boss?
If you can post some pics to help clarify this as well. Thanks..
Old 03-03-15, 08:49 AM
Ali SC3
Ali SC3's Avatar
the stock fuel rail fits import 11mm injectors. If you get an aftermarket rail for 14mm injectors, then you can use 14mm domestic injectors. these sizes are referring to the top o-ring on the injector and what size it fits into.
The lower half of the injector you should be able to fit the right size o-ring for the ge or gte runner (same size bottom o-ring) whether its import or domestic, you should not have to mess with the lower runner injector bosses at all, if you do you have the wrong injectors or lower O-ring.
nuturf87
04-08-19 10:09 AM
scblackout
05-20-16 03:32 PM
adam8103
SC400 / 300 Classifieds
09-03-09 06:14 PM
That-Guy
11-25-08 09:48 AM
Quick Reply: Domestic Injectors on GE
