Can someone please help. GS300 Fan in my 95 SC400
Hi Everyone and thanks for reading this. I have a 95 SC400 and I purchased a 2002 GS300 Fan assembly on ebay. Purchased a water pump and timing belt kit, all gaskets needed and I have all but 2 specialty tools and a optima battery to make room for the fan shroud to be completely ready for the swap. The setup barely clears it so I hope the optima is small enough to fit. The only thing is that I am for the life of me trying to figure out how to wire this and have it operate exactly as OEM GS fan works. Do I need to buy two temp switches? How then do I still see the temp in my car if I take out the existing sensors? Do I buy a radiator hose adapter with threads for 2 sensors? Has anyone used one? Anyone have wiring diagrams or can make one for me? I have searched on here but have not seen anything for the SC 400 specifically. I know for sure I need to have a 3 relay setup. I found a really nice guy named David Chapman from Hollister Road Company. He is going to wire the relay setup together but needs some help on how to wire it. Thanks!
Yo dude
Did you ever get anywhere with this? I wanted to do the same thing. According to lextreme, with our Stock fan removed we have 16x31 space for fans. How tall/wide are the 2nd Gen gs300 fans? Shouldn't they fit? Unless they are much wider. Please, I'd like to know any info on this. What are you using to mount?
bigjussin
11-11-12 12:28 PM
sexy sam
SC- 1st Gen (1992-2000)
08-27-08 05:31 AM
