Hydrofan / AC delete - What belt?
Im about to Megasquirt my SC400, and intend to drop some weight up front. The plan is to cut the hydrofan pump-pulley off and remove the AC. Then run a belt from the main pulley, through the tensioner / alternator / PS and the idle pulley by the thermostat housing, then back to the crank pulley.
Has anyone done this, and know what belt can be used? Please note that Im not using a idle gear on the hydro pump, it will be completely deleted!
