Fuel Pump ECU Rebuild
Old 01-15-15, 12:49 PM
Bankswood
Bankswood's Avatar
Originally Posted by CatManD3W
Just bypass the ECU like most do....
Well my fuel pump gave out 2 weeks ago. My mechanic who I really trust saw where I had bypassed the fuel pump ecu. He said regardless of what is said delivering 12 all the time will eventually burn up the fuel pump. I will say that I did the bypass 2 years and 45000 miles ago. I have noticed since I installed the new ecu My pump does not make noise.
Old 01-15-15, 01:05 PM
CatManD3W
CatManD3W's Avatar
I highly doubt the pump had failed due to 12V constant........If you old pump made noise it means it was already going bad...
Old 01-15-15, 04:01 PM
eknine9
eknine9's Avatar
Mine was working fine but I had misdiagnosed it as the cause of a start and stall problem so I bypassed it over a year ago. Could probably reconnect it now but I honestly don't see the point, and in the next 12-24 months I want to go Forced Induction so I'm just gonna leave it this way.
Old 01-15-15, 04:15 PM
Bankswood
Bankswood's Avatar
Well my new pump was making the slight raddle noise on startup also until I reinstalled the ecu
Old 01-15-15, 09:21 PM
TaninAuto
Sponsor
TaninAuto's Avatar
Yeah, there's no way it will burn out.
I have a custom GT35R setup on my 96 Land Cruiser. I installed a Supra TT pump and hard wired it with a relay. They are meant for consistent good voltage. Many pumps love additional voltage, up to 17V or so which is why the Kenne Bell Boost A Pump is made. Easy way to increase fuel delivery.
Anyways, we will watch for Banks' module and update with the results.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 01-16-15, 06:26 AM
Bankswood
Bankswood's Avatar
Mailed USPS this Friday morning.
Old 01-26-15, 03:59 PM
Bankswood
Bankswood's Avatar
Well I heard back from Tanin today. They can not repair the fuel pump ecu. The unit is sealed and after popping it open it became evident it was not designed to be repaired. Sooooo...
either but a new one, a used one or do the 12v mod.
Old 01-26-15, 04:03 PM
t2d2
t2d2's Avatar
^^^ Boo. Thanks for reporting back, though, and thanks to Tanin for looking into it!
bugjug
SC- 1st Gen (1992-2000)
02-15-11 04:41 PM
brad11140
02-04-11 05:45 PM
clean
05-20-07 10:03 PM
808SC300
Maintenance
10-07-04 09:31 PM
Quick Reply: Fuel Pump ECU Rebuild
