Happy New Year well maybe not
Old 01-01-15, 07:24 AM
Bankswood
Bankswood's Avatar
Default Happy New Year well maybe not
Driving my 93 SC 400 yesterday and it just quites in the middle of the road. Just stops running. I'm pretty sure it has somehting to do with fuel. I can't hear the fuel pump running. Can they quit in the middle of running. Thought they normally gave out on start up. Checked the 30amp fuse but it was good. Don't know how to tell if the relay is bad. can someone tell me how to bypass relay to see if that's the problem?
TIA
Old 01-01-15, 09:46 AM
Vrank
Vrank's Avatar
Jump fp and +b in the diagnostic port
Old 01-02-15, 12:30 AM
eknine9
eknine9's Avatar
search for "12v fuel pump mod" on the forums.
Old 01-02-15, 01:18 AM
kornpeef
kornpeef's Avatar
was it a quick die or a sputter then died. normally a quick everything shut off death is electrical related. alot of times battery post clamps loose and shifted not making good contact.
Old 01-02-15, 08:58 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Might benefit to check the coils and battery terminals/grounds.
Old 01-02-15, 12:03 PM
Bankswood
Bankswood's Avatar
update: It was the fuel pump. decided to go ahead and have thr starter replaced while it was in. Looks like a new timing belt later this month.
Old 01-05-15, 04:04 AM
Studiogeek
Studiogeek's Avatar
Why did they not combine starter and timing belt/water pump job?
Old 01-05-15, 04:26 AM
Bankswood
Bankswood's Avatar
They suggested it. I needed the car back for some work related travel. It was my call.
Old 01-05-15, 02:05 PM
Ali SC3
Ali SC3's Avatar
I shed a small tear everytime I read sc400 and starter. good luck hopefully your mechanic gives you a good deal.
Old 01-05-15, 05:51 PM
Bankswood
Bankswood's Avatar
Ali, I paid about $1000 for parts and labor on fuel pump and starter. Thing is my mechanic is very good and understands my love for the car. He does first class work and takes pride in his results.
NateDegram
08-13-17 09:45 PM
DoctorC
08-23-12 03:34 AM
hobojoe
08-31-10 10:27 AM
TroySC300
10-24-09 11:11 PM
stanatl
10-05-04 12:07 PM
Quick Reply: Happy New Year well maybe not
