SC400 Gas Mileage Issue
Old 12-04-14, 10:03 PM
Mastana
Mastana's Avatar
Default SC400 Gas Mileage Issue
Hey guys, i got a problem with my sc400. I have a 1998 Sc400 114k on the dash , it is giving me some issues. I'm getting 16 mpg and that's me driving calmly. I have a couple friends who are getting 18 mpg same year without an issue and they beat on their cars more than i do. I brought my car to 10 different mechanics and none of them had the answer to the problem. I change my battery, alternator, air filter , fuel filter , spark plugs, and used techron this was all done about 5,000 miles ago. I do my oil changes every 3k miles Mobil 1 fully synthetic 5w-30 and i fill up my car with BP, Exxon, Hess and Sunoco gas super all the time. Its weird i cant get to the bottom of this and find out why. Any comments, ideas , or help would be greatly appreciated .
Thanks for reading
Attached Thumbnails SC400 Gas Mileage Issue-iygwdpjeqs7swdkduniix3easpm3rcckfvd2v6m3ekw.jpg
Old 12-07-14, 05:17 PM
Dougspeed
Dougspeed's Avatar
The only two other things I can suggest is check your brake caliper pins to make sure they're not frozen and check the wheel alignment. But to be honest, 16-18mpg in the city is pretty normal. I'd only worry about it if you were getting this kinda mpg with a lot of freeway driving.
Old 12-07-14, 07:56 PM
durps
durps's Avatar
^This. Also buy new o2 sensors. I bought both my OEM densos on ebay for 85$ shipped. Try a new pcv valve, new gas cap seal, check tire psi, etc.
Old 12-07-14, 08:24 PM
t2d2
t2d2's Avatar
What would frozen brake caliper pins have to do with bad gas mileage? Wouldn't dragging brake pads be extremely obvious? I feel like I'm missing something here.
Old 12-07-14, 10:30 PM
grumpi300
grumpi300's Avatar
i'm just throwing an opinion out there, not a fact, but couldn't leaky capacitors potentially cause the same problem too?
Old 12-08-14, 12:48 AM
Dougspeed
Dougspeed's Avatar
Nope, unless both the upper and lower pins are frozen, it won't be "extremely" obvious with just one of the pins being stuck. Brakes might heat up a bit more than usual, but won't be burning hot since the brakes always have a small amount of drag by design, even when the pins are greased up and working properly. I had a frozen pin on one side and didn't notice till it came time to change my pads out.
Old 12-08-14, 08:58 AM
t2d2
t2d2's Avatar
Okay, now I need to go check my caliper pins...
Old 12-08-14, 10:20 AM
1997Soarer
1997Soarer's Avatar
^ This.
PCV valve, and raise your tires to 32 psi.
If that doesn't change anything, then replace the O2s (only the 2 primary's). They're due to be replaced anyway because of the age, but because they can be a real nightmare to change, I always tell people to replace them last
Also, inspect all your factory ground wires. Follow the - wire from the battery to the chassis and the engine and see its condition.
Old 12-08-14, 11:01 AM
NYKnick101
NYKnick101's Avatar
If your using a MPG dash counter, Reset it and start over. It could be just an estimated average of you and a bunch of other factors. ALSO switch up gas stations and run with one specific brand of fuel. I used to get from a local Citgo and half tank 93 premium driving around town would last 2 days (no more than 40 miles) but I switched up to Shell and I drove to CT 60 miles each way (120 total) and still have a quarter tank from a half
Old 12-08-14, 11:25 AM
Maserati
Maserati's Avatar
I had a caliper drag it sucks, Jack car up ,and spin the wheel for resistance. I was in the process of doing O2 sensors do i have to do all 4? or just the front?
Old 03-26-15, 11:34 AM
csalazar87
csalazar87's Avatar
Default You may want to change the capacitors in your ECU
I had this same exact issue...I was getting 10-12 MPG on my SC400 1992.
I bought it @ 111k and it was super clean but it had terrible gas mileage so I started searching CL.
Here's what I found:
https://www.clublexus.com/forums/ls4...capacitor.html
If you haven't already, change out the caps since they probably need to be replaced.
Good Luck!
p.s. I saw that you're in NJ...if you send me the ECU I can help you with this.
Old 03-31-15, 09:10 AM
Mastana
Mastana's Avatar
Good Luck!
Thanks I actually just dropped my car off at my mechanic yesterday and im replacing two o2 sensors, pcv valve, and a coolant temp sensor. If it doesn't do good after that then ill look into this. Also what county are you located in?
Old 03-31-15, 09:18 AM
csalazar87
csalazar87's Avatar
I live in bergen county but my buddy has his equipment in Carteret right off the turnpike. So if it doesn't work just shoot me a message.
We were able to replace everything in about 2 hours.
good luck!
Old 04-07-15, 02:17 PM
csalazar87
csalazar87's Avatar
Hey just an update...
I did a full tank test and I went up from around 225 miles per tank to around 378 or about 19MPG
WOOT WOOT!
Old 04-10-15, 09:40 AM
Mastana
Mastana's Avatar
good luck!
WOOT WOOT!
NICE! I wish that was me lol But are you going to the meet april 12 in jersey city at liberty state park?
Quick Reply: SC400 Gas Mileage Issue
