crank pulley will not come off
Old 11-04-14, 01:42 PM
erock202
erock202's Avatar
**** I already bought the obx. And I am out of money now
Old 11-04-14, 01:44 PM
erock202
erock202's Avatar
I am in winchester
Old 11-04-14, 01:45 PM
99SC42
gte & na-t
99SC42's Avatar
Save up for another engine then...I am telling you whats gonna happen.
The obx doesn't have any rubber on it to dampned the vibrations , it will cost you your engine.
Do not do it.
Old 11-04-14, 01:47 PM
erock202
erock202's Avatar
Originally Posted by 99SC42
No no No , you do not want an obx, it will destroy your engine in couple minutes....You don't wanna do that.
If you want something that will not break and last you , get the ati damper.
How much is that and where do I get it I just paid 65 plus 10 for shipping for the obx and this issue has ran me broke. This is my only car and I haven't even been able to go to work.
Old 11-04-14, 01:49 PM
99SC42
gte & na-t
99SC42's Avatar
Ok then get a used stock one for now till you save up some money for the ati one.
Whatever you do do not used that obx crap, you will end up spending more money..
What part of VA are you from?
Old 11-04-14, 01:58 PM
erock202
erock202's Avatar
Winchester I just replaced it with a stock one and it fell apart in two weeks that's why I wanted to go with one without the harmonic balancer.
Old 11-04-14, 02:06 PM
turbodremz
turbodremz's Avatar
What are you using to apply heat to the pulley? Are you making sure your heating only the pulley and not the crank snout?
99SC42
gte & na-t
99SC42's Avatar
Well I don't think you wanna do that...but you can try it if you want.
Old 11-04-14, 02:12 PM
Ali SC3
Ali SC3's Avatar
don't skip on the harmonic balancer, get one back on there ASAP. there are lots of cars you can get it off of.
Old 11-05-14, 03:40 AM
lexforlife
lexforlife's Avatar
or better yet , get the fluid damper and no need to change belt size and the fluid damper dampens thru out entire rpm band
Old 11-05-14, 05:39 AM
mecheng10
mecheng10's Avatar
what might help is to cut some slits with a cutoff wheel on the pulley near the crankshaft to help ease some tension off of the crankshaft.
Old 11-18-14, 05:15 PM
dalechek
dalechek's Avatar
I went through two rentals from O'reilly's before I was able to get it off, in the end it took a ton of pb blaster, 2 days, and a 3 hook pulley puller.
Old 11-19-14, 01:07 PM
turbodremz
turbodremz's Avatar
OBX parts are good for one thing, and one thing only...to make decorative clocks for your garage/shop. They sell clock kits at hobby lobby, michaels crafts and at home depot.
Clean your stock pulley, clean the crank snout (some 00 steel wool will work good and more PB Blaster), and reuse that. Yeah the OBX looks....err....neat, but might as well toss some liquid glass in with your next oil change.
Old 11-19-14, 01:22 PM
CatManD3W
CatManD3W's Avatar
Just use the OEM pulley.......and use the OBX as a paper weight
Old 11-20-14, 09:19 AM
Ali SC3
Ali SC3's Avatar
anyone know if you can use one from a 2jzgte on a 2jzge? has anyone tried that? Is there an advantage like the rubber is stronger or basically the same as the ge part?
Quick Reply: crank pulley will not come off
