SC400 takes longer to start up after fuel pump replacement
Old 10-15-14, 01:55 AM
blake96
blake96's Avatar
Default SC400 takes longer to start up after fuel pump replacement
So i just replaced my fuel pump as preventative maintenance on my 92 sc400 and now it takes double the time to start. Airtex OEM fit). What could it be?
Old 10-16-14, 05:35 PM
bigwhite
bigwhite's Avatar
Just put a new Airtex in my 93, and did the fuel pump ecu bypass and it starts in 80% less time. Aside from the bypass, tune-up and ECU is about all thats left.
Old 10-16-14, 06:40 PM
t2d2
t2d2's Avatar
I've tried pretty much everything to address the long-crank starts on mine. Plugs, wires, caps & rotors, checked coils, fuel filter, swapped in a used fuel pump, fuel injectors, fuel pressure regulator, charcoal canister, ECU capacitors, vacuum lines... None of it has consistently helped. For some reason, fuel pressure drops when the car is shut off, but every hunch has proven to be a dead end.
The two things that have worked consistently are:
1) A quick bump of the starter, wait a second, then turn the key again.
2) Fuel pump ECU bypass. Wait a couple seconds with key in the "On" position, then crank it. I've only done it by jumpering the pins in the diagnostics box at this point, not the permanent bypass.
Both methods bring the fuel pressure back up to where it should be. It may just be an unsolvable mystery what's allowing it to drop... I've exhausted all the likely culprits.
Old 10-21-14, 06:14 PM
bigwhite
bigwhite's Avatar
Do you have air pressure blowing out the gas cap when you refill at the gas station?
Old 10-21-14, 06:34 PM
t2d2
t2d2's Avatar
Me or the OP?
Yes, I have what seems like excessive pressure (but no consensus that I could find about how much pressure is ideal) when opening the gas cap, to the point that gas will pour up and out of the spout when fairly full. That's why I looked into the charcoal canister, in case the venting system wasn't working properly. I haven't figured out how to disconnect that line at the tank end, though, and see if air will blow through.
Old 10-21-14, 06:52 PM
bigwhite
bigwhite's Avatar
The OP seems to have a worse case.
Old 10-21-14, 08:06 PM
t2d2
t2d2's Avatar
I doubt that. If I don't employ one of the two workarounds, mine will crank for 3-4 seconds before starting. That's definitely more than double normal, which is what the OP stated.
Old 10-22-14, 05:58 PM
bigwhite
bigwhite's Avatar
So do either one of you have pressure blowing out of the gas cap when you refill?
Old 10-22-14, 08:24 PM
t2d2
t2d2's Avatar
I can't speak for blake96, but I already answered that in post #5.
Old 10-23-14, 07:51 PM
bigwhite
bigwhite's Avatar
Must have overlooked #5, just wanted to make sure you had pressure on the system. I know there were some faulty gas caps.
Old 11-03-14, 06:07 PM
blake96
blake96's Avatar
Sorry about the late response... I am now thinking that the fuel lines i reconnected to the fuel pump aren't clamped down tight enough ant the pressure leaks out into the tank. There is obvious built up pressure wher I remove the gas cap.... only thing I can think of.
Old 11-03-14, 06:31 PM
t2d2
t2d2's Avatar
Interesting theory, let us know if it pans out! I've looked into related aspects (the pump's pressure relief valve and return/tank venting), but hadn't considered the hose to the pump itself being suspect. It doesn't take much to make an old hose leak if the clamp isn't put back exactly where it was before... I just had that happen last week with the upper radiator hose, in fact.
I had the long-crank problem prior to first swapping pumps, but maybe the hose was already fading or a previous owner had also fiddled with it and didn't get the clamp right. It's about as plausible as any remaining options.
tenac2215
03-23-17 11:20 AM
Lexus082
07-10-14 09:31 PM
codetoad
07-26-09 02:45 AM
O. L. T.
SC400 / 300 Classifieds
01-22-05 04:37 PM
808SC300
Maintenance
01-18-04 11:22 AM
Quick Reply: SC400 takes longer to start up after fuel pump replacement
