Help with Power Steering Pump
Old 08-06-14, 09:13 AM
therampage
therampage's Avatar
Default Help with Power Steering Pump
I'm replacing the PS Pump on my 95 SC400 and while I was removing everything I got 3 of the bolts out but the top rear bolt is starting to strip and it's super tight. Any ideas on how to go at this thing before I completely destroy the bolt?
Old 08-15-14, 03:58 PM
PZski
PZski's Avatar
I removed top first so weight was not held by that bolt.
Opposite problem....same car....
Unit and reservoir out, but high pressure line remains attached. Can't break either at bottom cross member
or the 22mm nut on the unit. Suggestions?????
sparkyguy
12-05-16 07:23 PM
Mike1JZ
12
09-20-13 05:34 AM
Norbecke
06-27-12 08:53 PM
rome99LS
01-20-12 02:08 PM
S30ZG
09-27-09 07:45 AM
Quick Reply: Help with Power Steering Pump
