97 fogs on a 93 sc
Old 08-02-14, 11:16 PM
soarer1988
soarer1988's Avatar
Default 97 fogs on a 93 sc
What do i need to make the fogs on my 97 front bumper work and will the 93 fog plus fit i dont want to take off my bumper just to see it dont plug in lol help me out
Old 08-02-14, 11:30 PM
oldManTan
oldManTan's Avatar
they won't fit at all. the 92-94 bumper has rectangular vents on the sides where the turn lights go, the later model fog lights are round, so you'll have to do some cutting. i might be wrong though, do a google search maybe you can find something
Old 08-03-14, 03:20 AM
KahnBB6
KahnBB6's Avatar
Received 1,216 Likes on 854 Posts
I've done this on my 1993 model. It requires a bit of work but it's not an insurmountable task. Fog lamps are much more useful than the early cornering lamps, even if you have an HID conversion.
You'll need:
-1997-2000 front bumper conversion (and the little bezel in the grille & Lexus badge, etc.)
-97+ fog lamps (of course)
-x2 Nuts (rear of housing) 90179-05088
-x4 Screws (top and side of housing) 90159-50225
-x2 97 fog lamp connectors (90980-11156)
-Spare electrode/wire for those connectors if you have anything you've kept from phone wiring, etc. If not, Sewell Lexus or Carson Toyota can probably source them for you
-A custom made foglight wiring and relay harness as per O.L.T.'s thread listed below (I also recommend some round plastic wire protector tubing while you're at Radio Shack)
-An interior switch
I won't go into great detail but other than the bumper conversion you have to clip and tie up your cornering light wiring that goes in the same location as your future 97 fog lights. It's unusable because the voltage is around 15v and variable depending on whether or not the headlights are on and whether or not your left or right turn signal is on. So you must create your own fog wiring harness. It is best to wire the relay trigger (as in the thread) to your parking lights rather than your headlights. This way your fog lights can be switched on independently of your main headlights but will also shut off along with ALL your front lights when you turn the factory stalk to "OFF" or leave it in "AUTO" and the car senses that it's daytime.
Here is the meat of creating the harness, thanks to O.L.T.:
https://www.clublexus.com/forums/sc-...og-lights.html
You can also search for other visual diagrams online (i.e.: "how to make a foglight relay harness") and you will find it's the same basic principle. I'm very visual and needed more picture examples before doing mine but his guide is exactly how you do it and helps you identify some crucial SC specific wiring.
Then there are a few threads I made to clarify some things:
https://www.clublexus.com/forums/sc-...fog-lamps.html
https://www.clublexus.com/forums/sc-...mp-switch.html
https://www.clublexus.com/forums/sc-...or-switch.html
And finally a DIY I made detailing how to cleanly get your aftermarket on/off switch into your dash area. You COULD try converting to a 1995+ light control stalk with the foglight selector but this is even more involved and involves getting into the steering column collar. So the easier solution is adding a simple interior switch.
https://www.clublexus.com/forums/sc-...ngine-bay.html
Good luck and hope this helps!
Last edited by KahnBB6; 09-27-14 at 01:46 AM. Reason: Updated with 97 fog light housing connector P/N
Old 08-03-14, 01:31 PM
ArkLaTexSC
ArkLaTexSC's Avatar
I simply wired my 97s with my turn signals as the old cornering circuit was bad. Has a unique look and stopped hyperblink.
Old 08-03-14, 10:10 PM
KahnBB6
KahnBB6's Avatar
Wouldn't the much brighter fog lamps only come on with your turn signals then, blinking in unison?
Old 08-03-14, 11:01 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Precisely. It's still strange but not quite as strange as the oem corners!
crza81
SC400 / 300 Classifieds
05-10-17 09:02 AM
LexiiBabe
02-16-16 01:58 PM
Studiogeek
SC- 1st Gen (1992-2000)
12-10-14 06:49 PM
sidwin
11-01-12 02:38 PM
GT60Lex
08-01-05 06:45 AM
Quick Reply: 97 fogs on a 93 sc
