Defeating/Bypassing the Coolant Level Sensor?
Old 07-31-14, 07:00 PM
DanielDD
DanielDD's Avatar
Default Defeating/Bypassing the Coolant Level Sensor?
I just replaced my coolant reservoir with a newer used one that didn't have a coolant level sensor. It appears to be not available on the 95 and later cars. Mine is a 93 and was leaking, so this is why I replaced it. I thought I could easily disconnect the coolant level sensor and just short the connector and bypass it, but the indicator light came on anyway.
Investigation of the coolant sensor indicates a resistance reading of 8M ohm. If I invert the sensor, I get 9M ohm, so there is a 1M ohm difference between when its sensing whether there is coolant in the reservoir or not. Since I didn't readily have a 9M ohm resistor, I reconnected the sensor and inverted it and placed it in the engine compartment for the time being. I have yet to test this as its late in the evening….
I don't like the jury rig solution to defeat the low coolant light. Anybody done this in a more professional manner?
Old 07-31-14, 08:04 PM
t2d2
t2d2's Avatar
I'm not sure how they differ visually -- didn't know they differ at all -- but can you modify the newer one to accept the older one's sensor?
Old 08-01-14, 07:02 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
The reason we dont really like the reserviors with the sensors, (92-94) is because they crack easily right beside the sensor. It's just a crack point. Guess where a crack is on my 92 SC? Beside the sensor.
Also I don't think one can simply drop the sensor in to the 95-up reservior.The mold that covers the hole is apart of the container.
Old 08-01-14, 08:09 AM
t2d2
t2d2's Avatar
I was envisioning cutting a new hole and rigging up some sort of lip for the sensor and cap. Something along the lines of a PCV Valve grommet to seal up the opening and give you something to mount to.
Old 08-01-14, 08:21 AM
DanielDD
DanielDD's Avatar
Well, for right now, I hooked the sensor back up in the inverted position and secured it next to the coolant reservoir. At least the idiot light is no longer on until I can find a more permanent solution.
A 9Meg ohm resistor should do the trick.
Old 08-01-14, 01:20 PM
Dream36
Dream36's Avatar
I was under the impression that zero ohms equals happy sensor. Ie. unplug it and the car will think its full. Mine is currently cracked all around the sensor so I took a plastic bag (the kind I work with is really thick like a triple thick garbage bag maybe) and covered the res with weekly refills. This is to gimp along till I can afford a new res. if I am wrong please correct me as Id like it to run right
My plan is to use a howe expansion tank instead as it's aluminum and won't crack later down the road (and cheaper too) the RX7 swaps use this with the ls1. Lol if I can find where I bought it last time I'd already have fixed it.
Anyway good luck. I currently have my sensor in the res but not connected, no lights in the dash. Although I am still chasing a hesitation problem I thought was caused by the coolant spraying my whole bay. Could be tps or maf at this point (no codes either)
Old 09-22-14, 04:13 PM
pcolex
pcolex's Avatar
My sensor is not connected and the light stays off. I keep it unplugged because the light is always on, regardless of the coolant level. I'm guessing this is because my sensor is bad, however I haven't verified this issue because I have more pressing things that are bugging me like brakes, shocks, trunk struts, etc.
Old 09-22-14, 06:34 PM
oldManTan
oldManTan's Avatar
subscribed because i'd like to change my ugly @$$ coolant reservoir.
Old 12-04-14, 03:55 PM
pcolex
pcolex's Avatar
I previously had my sensor disconnected, which got rid of the idiot light problem. But I changed my tune. I had a heater hose break, and then my water pump went out. Through those repairs I replaced the sensor and I am very happy I have done so because there's comfort in knowing the coolant level is just right. The part is like $80-90 from lexus.sewellparts.com. I'm really glad I replaced it. Super easy repair.
afpj
RX - 3rd Gen (2010-2015)
02-24-18 10:43 PM
RJ1968
02-02-18 02:35 PM
mjr955201
06-08-16 12:29 AM
LeftSideES
03-27-16 12:35 PM
SCpwner
11-21-08 08:01 AM
Quick Reply: Defeating/Bypassing the Coolant Level Sensor?
