1JZ custom patch harness, or just splice/solder?
Old 07-31-14, 12:43 AM
Matt300ZXT
Matt300ZXT's Avatar
Default 1JZ custom patch harness, or just splice/solder?
I did quite a bit of reading yesterday on the wiring work needed to put a Soarer 1JZ/harness into my SC300. I've seen most people say splice/solder, or drill holes in a new area and don't worry about having to splice/solder, and some people just leave half of the harness alone and just let the ECU dangle where it may. I'm sure my idea has been tried before or whatever, but what would be any different about splice/soldering a billion different wires than having Boomslang or some other patch harness maker custom making a 21" patch harness to snap in place between the harness and ECU?
If that won't work like I'm thinking, I don't mind splice/soldering, just trying to figure up a clean alternative.
Old 07-31-14, 01:09 AM
SC2JZ300
SC2JZ300's Avatar
Patch harness makes it simply easier.
Old 07-31-14, 07:34 AM
Vrank
Vrank's Avatar
No matter what body side would have to be extended at a minimum via cut/solder. I've seen a swap that was done using a boomslang patch harness for the engine function portion and extended on body side only. Ecu still wasn't in the proper place.
Old 07-31-14, 07:50 AM
Matt300ZXT
Matt300ZXT's Avatar
Yeah, apparently most patch harnesses are only 10" or so, hence Boomslang making one 21" long. Its something ill keep weighing options with since some plugs do still need to be addressed. Depends heavily on their asking proce for custom work.
soarer13oy
soarer13oy's Avatar
You might as well extend the entire harness for a clean look. Like Vrank said youll have to extend the body plugs anyways. Anyone who is letting their ecu dangle i would say is pretty darn lazy.
Cetura
IS - 1st Gen (2001-2005)
11-10-16 12:35 AM
SC2JZ300
SC400 / 300 Classifieds
07-22-09 12:02 AM
cino78h
10-27-06 06:17 PM
MadMaxxNA
07-17-05 08:46 AM
Quick Reply: 1JZ custom patch harness, or just splice/solder?
