SC400 P/S Buzz question
Old 07-26-14, 07:53 PM
Farino81
Farino81's Avatar
Default SC400 P/S Buzz question
So lately my P/S has been making alot of buzzing noise when I turn the wheel. Fluid level is good and was changed about 20k ago. I have a 94 sc400. Does it sound like my pump is going out or my p/s rack?
Old 07-27-14, 08:30 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
If fluid level is going down and there is white smoke coming from the exhaust, then you have a failed vacuum valve, the PS pump also will do this when low on fluid, but if level checks out good then the PS pump could be worn out.
Old 07-28-14, 08:09 AM
Kris9884
Kris9884's Avatar
Yeah if the fluid is not depleting then its a pump on it's way out. Mine's been doing the same thing for about 2 months and recently getting worse and harder to hold the wheel while turning. It's last leg..
Farino81
01-25-12 03:52 PM
larryhirs
03-08-10 03:43 PM
phillipin
07-15-05 05:01 PM
VSsc400
SC- 1st Gen (1992-2000)
18
06-10-04 05:07 PM
HotBoy
Maintenance
26
06-01-04 08:45 AM
Quick Reply: SC400 P/S Buzz question
