Is this an R154?
Old 07-25-14, 03:54 PM
Matt300ZXT
Matt300ZXT's Avatar
Default Is this an R154?
I don't know the transmissions just by looking at them, just curious if you guys could give me a quick yes or no. Thinking about going to buy it tomorrow to start my collection for the 1JZ/R154 conversion.
Old 07-25-14, 03:55 PM
Matt300ZXT
Matt300ZXT's Avatar
Also, is $1200 a fair price for it with 109k on it?
Old 07-25-14, 05:24 PM
97-SC300
97-SC300's Avatar
Looks like an R154 to me.
Old 07-25-14, 07:03 PM
1CleanSC
1CleanSC's Avatar
1200 for just the transmission? Lol no way in hell is it worth that. Unless it comes with pedals, driveshaft, etc.
Old 07-25-14, 07:13 PM
Cleanshots
Cleanshots's Avatar
hell no.. worth 500 bucks max.. no drive shaft, no jz bell housing.. no nothing.. i paid 1200 for entire swap shipped to my door..
Old 07-25-14, 07:59 PM
scENFORCER
scENFORCER's Avatar
Wow, you cant find an R154 for under $1k where I'm from. Most of them go for $1500 even.. lucky guys.. lol
Old 07-26-14, 03:01 PM
LEXXIUM
LEXXIUM's Avatar
Yeah that's from the mk3 supra, not a soarer
Old 07-26-14, 03:02 PM
LEXXIUM
LEXXIUM's Avatar
500 is about a good price
Old 07-27-14, 08:54 AM
INTIMAZY
INTIMAZY's Avatar
Soarer R154s go for UP TO $~1000 but thats no bargain.
With the MK3 the shifter will be i the wrong spot. $500 would be a good deal for one of those.
Old 07-28-14, 01:47 AM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
^^ I have seen Soarer R154's go for a bit more than $1k. *Built* R154's are definitely up there a bit more. $1200 seems a bit high for an MKIII R154 even with only 109k. I bought my MKIII R154 with 111k for $850. I was able to see the nearly stock '89 Turbo it came from and verify the odometer myself. $500 might be for significantly higher mileage.
There is nothing wrong with an MKIII R154 but it does need a 1JZ bell housing, extended shifter, Marlin Crawler VSS adaptor and a custom trans mount and crossmember solution (several approaches for achieving that).
Old 07-28-14, 10:30 AM
Matt300ZXT
Matt300ZXT's Avatar
Oh, I thought it only needed the bell housing and shifter, hadn't researched it too much but wasn't aware it needed different crossmember/mounting goodies. Oh well, I'll use the bit of it being an MK3 unit to my advantage next time I come across one that isn't a Soarer unit. Thanks for the info.
Old 07-29-14, 12:18 AM
KahnBB6
KahnBB6's Avatar
^^ Sure. It's a good transmission and internally the same as a Soarer R154 other than the synchros and bearings in the later Soarer/Chaser "tripod" versions. The Soarer/Chaser versions just need less changed to get them bolted in.
SOLID300
15
02-16-13 08:40 AM
94_soarer
SC400 / 300 Classifieds
10-15-11 06:04 AM
bryan767
SC- 1st Gen (1992-2000)
21
03-02-11 10:40 AM
djkevin510
05-23-08 11:07 AM
jefferino
28
06-16-07 06:41 PM
Quick Reply: Is this an R154?
