1.5jzge just need a little info - Club Lexus Forums
Thread Tools Search this Thread
Old 07-25-14, 12:43 AM   #1
chillchewy
Default 1.5jzge just need a little info
So I recently bought an 95 sc300 and ive been looking in too the 1.5jz ge and I know most of what I need. I wanna go with a t67 turbo and 272 hks cams. I know I need to get a 1jz harness and get it extended. Im going with gte pistons, rods. Im gonna go with a 1jz ecu. Is there anything else i need to get this working? Ive been searching alot about this im about 2 months in of research but I havent found a specific parts list
chillchewy is offline   Reply With Quote
Old 07-25-14, 06:08 AM   #2
vipsoarer
vipsoarer's Avatar
If you are going this route and using the GE and not the GTE block, you will need to drill and tap for the oil drain into the oil pan. You don't need the GTE pistons and rods as the GE ones are the same (as long as it isnt a vvti block). The rest is just following a 1jz swap list and switching out the block.
vipsoarer is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
1.5jz auto transmisson question mmac0405 Performance & Maintenance 2 01-03-17 08:41 PM
quality 1jz single manifold? 93MSB Performance & Maintenance 21 03-01-16 08:43 AM
1.5JZ w/EGR Possible? GISguy Performance & Maintenance 12 07-19-15 01:23 PM
Sc400 2jz swap, need a bit of info & help Scjunky94 SC- 1st Gen (1992-2000) 0 04-03-15 08:47 AM
2jz to ka24de 5 speed chillchewy SC- 1st Gen (1992-2000) 1 12-24-14 10:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
