car missing need help please....
Old 07-20-14, 02:41 PM
1980's Avatar
Default car missing need help please....
my 94 sc300 started missing the other day so i changed the plugs and wires.didnt fix it. so i started looking into it a bit and found the number two injector was not firing. no big deal i change the injectors. all six with new ones. still not fixed. still has the injector not firing. so i got to reading and found the ecu caps could be bad. sent ecu off to get fixed waited forever. but got it back. plugged it in and still not fixed.ive changed everything i can think of. so what else could it be. timing is dead on i have voltage to the plugs and injector. injectors all fire. what could it be.please help. any ideas would be great. thanks.
Old 07-20-14, 03:09 PM
t2d2
t2d2's Avatar
Did you check the coils?
Old 07-20-14, 05:23 PM
1980's Avatar
no coils. 2jzge.
Old 07-20-14, 05:39 PM
t2d2
t2d2's Avatar
Ooh, didn't realize the SC300 is coil-less. That's all I've got, sorry.
Old 07-20-14, 08:44 PM
Vrank
Vrank's Avatar
Kinda confused. You said number two injector wasn't firing, changed stuff, still isn't firing, then all injectors firing. What's the cap and rotor look like?
Old 07-21-14, 07:30 AM
mecheng10
mecheng10's Avatar
did you pull the plugs?
what did the plugs look like?
have you checked your maf?
tps?
Old 07-21-14, 09:38 AM
Ali SC3
Ali SC3's Avatar
I would check the injector clips, and as said above cap and rotor and there is one coil on the 2jzge.
Old 07-21-14, 05:03 PM
1980's Avatar
i checked the plugs. they are all good. replaced the plugs wires and cap rotor button. all new. no burns or spark jump. the injector number two was not firing put in new injectors all 6. not sure if they r opening or not but i did check the injector plugs. they all have voltage. tps and maf are good. car runs just missing some. ive heard that if a valve sticks it could cause the same problem. which makes sense to me. has fuel has spark just no combustion in one cylinder because its open or partly open. everything is new injectors rotor cap plugs wires. only thing i can think is to do a compression check. unless anyone here has some other info. anything would help. im sure its just something im not seeing and will feel dumb when i find it. thanks for you help guys.
Old 07-21-14, 07:08 PM
wth98sc
wth98sc's Avatar
And I clicked on the thread thinking you misplaced your SC.
Old 07-22-14, 12:13 PM
1980's Avatar
nope didnt misplace my sc. its still sitting in the driveway not running right.
Old 07-22-14, 12:46 PM
mecheng10
mecheng10's Avatar
when was the last time you changed your fuel filter?
its a long shot, but it might be clogged and allow inadequate gas flow.
Old 07-22-14, 07:40 PM
1980's Avatar
fuel filter is about three months old. should be good.
Old 07-23-14, 06:03 AM
mecheng10
mecheng10's Avatar
how about your O2 sensors? well the upstream one.
on my prelude when the upstream O2 sensor was bad, it would misfire randomly
Old 07-23-14, 07:59 AM
soarer13oy
soarer13oy's Avatar
Check for continuity from the ecu to #2 injector.
Old 07-23-14, 04:28 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Unless I missed something, what about the fuel pump control ECU? Try the 12v mod...
Quick Reply: car missing need help please....
