what radiator do i have?
Old 07-16-14, 09:55 PM
oldManTan
oldManTan's Avatar
Default what radiator do i have?
i obviously got this car with the radiator already in it. i've looked around and it doesn't look like a stock radiator for an SC400? i usually see a rounder one. i've only seen one other picture with the same radiator. the tan one is mine, the red one is off the interwebs
Attached Thumbnails what radiator do i have?-dsc_0053.jpg   what radiator do i have?-sm1992-lexus-sc400-3-2011-001.jpg
Old 07-16-14, 10:53 PM
ArkLaTexSC
ArkLaTexSC's Avatar
OEM. It's in my '93.
Old 07-18-14, 09:00 AM
Dougspeed
Dougspeed's Avatar
All OEM radiators are plastic capped, yours is a generic aftermarket radiator with metal caps. I know this because I had to replace the OEM plastic one and decided I wanted to go with a metal radiator. ArkLaTexSC, if you have that metal one, it's also a generic brand aftermarket radiator, not OEM. The OEM part also has the word Toyota along with the part number stamped on it right at the top near the upper hose as seen in the pic of the red one.
Here's an eBay link to the metal aftermarket, brand is CSF.
http://www.ebay.com/itm/Lexus-SC400-1992-1997-All-Metal-Radiator-CSF-NEW-16400-50061A-/170848434491?_trksid=p2054897.l4275
Old 07-18-14, 11:48 PM
oldManTan
oldManTan's Avatar
Lexus sc400 1992 1997 All Metal Radiator CSF New 16400 50061A | eBay
cool thanks guys.
Old 07-19-14, 12:30 PM
t2d2
t2d2's Avatar
This is funny, because mine looks the same as the generic aftermarket one above. I've been trying to figure out where my radiator drain **** is, following various DIY instructions. I finally put the car up on ramps today to work on a couple things and had enough room to slide all the way under for a closer look. Turns out my radiator has a thumb screw drain way over on the driver's side, not the passenger side like OEM, and no hose hanging down to be able to spot it from anywhere but directly below.
HarrierRX300
RX - 1st Gen (1999-2003)
01-04-23 09:34 AM
KA8
12-04-15 03:25 PM
coolewong
SC- 1st Gen (1992-2000)
18
09-08-11 10:37 PM
vj3
12-27-10 07:04 AM
Quick Reply: what radiator do i have?
