Help my 1jz auto dies!
Old 07-12-14, 02:49 PM
rwdpwr
rwdpwr's Avatar
Default Help my 1jz auto dies!
hello ive tried changing all of my fuses and problem is still persisting. when i turn key there is no response from anything. the dash lights stay on as if nothing was actuated.
i jumped my starter from the relay and car cranks up fine in park and neutral.
heres the kicker.
after starting the car i can shift into any gear as long as i do it really quickly but if try to go from P to Reverse, the car will go into gear and stay on. Now when i trow it into neutral the car stalls out immediately. This has never happened before and ive had this car swapped for years. same with D, if i turn on the car in P and shift to D quickly it stays on. even if i do O/D, 2nd, and 1st. just when i shift into neutral, the car stalls, immediately. could this be a NSS or ECU issue? im so confused
like i said this swap has run flawlessly till recently and i have no idea why it dies when shifting into neutral
Any suggestions or help??
thanks in advanced
henry
Old 07-12-14, 07:25 PM
BiGEZ
BiGEZ's Avatar
Are you using the Soarer ECU? It could be the ECU they are know to go bad. Also check all the connections on the tranny.
JonBlaze2g
SC- 1st Gen (1992-2000)
01-05-15 11:40 AM
estomax
10-07-14 04:52 PM
dandd2
01-24-13 07:16 AM
Yahoo27
12-09-09 05:49 PM
AB85
07-02-09 02:34 AM
Quick Reply: Help my 1jz auto dies!
