Common 1jz problems?
Old 07-03-14, 11:52 AM
brandenGs3
brandenGs3's Avatar
Default Common 1jz problems?
So I was contemplating swaps and just would like to get an idea of what are some common problems on the 1jz? i have only heard of rod knocks anything else? i dont expect much being it is built from toyota but i would like some input
Old 07-03-14, 12:09 PM
soarer13oy
soarer13oy's Avatar
It all depends on the condition of the motor when you do buy it and what kind of preventative maintenance you do before putting the motor in. I say if youre going to do a swap go with a 2jz
Old 07-03-14, 12:58 PM
chnk
chnk's Avatar
my 1jz has no signs of rod knock and i've been pretty hard on the car.
Valve stem seals is a common
Old 07-03-14, 05:14 PM
OnyxBubble
OnyxBubble's Avatar
Check the crank pulley for signs of dry rotting in the dampener rubber.(1jz and 2jz). Ive heard stories of crank walk (1jz)but never actually saw anyone who had that issue.....
Old 07-03-14, 05:20 PM
1JAllDay
1JAllDay's Avatar
rod knock on a 1j? never seen it before unless its a tuning error or owner error
Old 07-03-14, 08:03 PM
brandenGs3
brandenGs3's Avatar
i am really familiar with the 2jz set up and motor and all its just freaking expensive for the swap i guess ill just have to continue to wait for that right moment. im just getting eager to do more to my car.
Old 07-05-14, 08:09 PM
INTIMAZY
INTIMAZY's Avatar
Maybe the weak stock twins when pushed past 18psi? Leaking ECU capacitors? Not many significant things I can think of.
Both motors:
Valve cover gasket leaks.
Crank pulley as someone mentioned.
Cracked coils.
Valve stems as mentioned as well, but I think most owners just ignore it.
I've seen a crank walked 2JZ before and many owners on the forums post about it. It probably applies to 1JZ as well just haven't heard or seen one yet. Disable the clutch switch.
shivan0124
02-13-12 05:19 AM
PoGikoSc4
Southeast
02-08-11 01:57 AM
romycha1
17
05-29-09 01:43 PM
hemogoblin
22
06-07-06 08:17 PM
Quick Reply: Common 1jz problems?
