Accessories on 2jzgte swap
Old 07-02-14, 02:52 AM
2jdeemo
2jdeemo's Avatar
Default Accessories on 2jzgte swap
Can't seem to find this info. To much un-needed things or not using the right key words but I was curious what accessories wouldn't work if I did the 2jzgte swap in my sc300 and used the wiring harness it came with.
Old 07-02-14, 08:34 AM
soarer13oy
soarer13oy's Avatar
I lost traction control, and the ect/pwr button. That all i can think of that i lost.
Old 07-02-14, 01:00 PM
2jdeemo
2jdeemo's Avatar
That's it? Did u use a supra motor set or aristo?
Old 07-02-14, 01:32 PM
Highway
Highway's Avatar
I lost nothing with the Aristo motorset w/auto aristo ECU on my original 1995 sc300 5spd. I however use a complete tweak'd harness and Tweak'd modified tach . As it is right now my battery dies if it sits. After researching before I even did the swap I saw users reporting the same. So in short you have to address the tach & explore using a complete aftermarket ECU. GL
Old 07-02-14, 02:16 PM
CatManD3W
CatManD3W's Avatar
With the Aristo swap you will need to use the SC300 A/C compressor.....the lines bolt up different and are a different size on Aristo....
Old 07-02-14, 03:40 PM
soarer13oy
soarer13oy's Avatar
I used an aristo motor but its basically the same as a supra.
Old 07-02-14, 10:18 PM
2jdeemo
2jdeemo's Avatar
I'm mostly asking about the harness not the motor. And my ac lines are busted anyways so no ac for me ahaha
Old 07-03-14, 02:00 AM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Hang on... why does the 2JZGTE swap cause a battery drain gremlin? Is there some issue with using an OEM GTE ecu?
Old 07-03-14, 09:31 AM
soarer13oy
soarer13oy's Avatar
I dont seem to have a battery drain issue, but im not using a tweak harness either.
Old 07-03-14, 10:44 AM
CatManD3W
CatManD3W's Avatar
x2.....No battery drain here....Im not using tweak either.....Your battery may just be cooked....Go get it checked at an auto parts store they usually do it for free
Old 07-03-14, 01:39 PM
2jdeemo
2jdeemo's Avatar
What harness are u using?
Dvemon
12-25-17 03:54 PM
angus
Performance
13
06-03-16 03:52 AM
sunrisetrd
11-20-08 08:57 PM
DSMpower
11-10-07 12:27 AM
StimpzSC3
10-22-07 02:17 PM
Quick Reply: Accessories on 2jzgte swap
