Mishimoto Aluminum Radiator
Old 06-16-14, 10:26 PM
SOARER525
SOARER525's Avatar
Default Mishimoto Aluminum Radiator
Which radiator is best to replace my 95 sc400. Does mishimoto carry for the sc400?
Old 06-17-14, 06:16 AM
mecheng10
mecheng10's Avatar
stock radiator is awesome.
Toyota over engineered the cooling system from factory.
but if you want the look of an aluminum radiator, you can use the supra tt radiator.
https://www.clublexus.com/forums/per...ator-pics.html
Old 06-17-14, 04:46 PM
Luxor
Luxor's Avatar
I have a Supra TT Mishimoto radiator. You will need to buy a Supra fan shroud and also install an external transmission cooler and also a shroud bracket.
Old 06-17-14, 06:55 PM
KahnBB6
KahnBB6's Avatar
Received 1,216 Likes on 854 Posts
^^ Yep to all of the above. Even the expensive OEM Supra TT radiator is an extremely reliable and strong unit. Fan shroud and external auto transmission cooler aside it is just cheaper to go with a Mishimoto or Koyo aluminum radiator swap.
2022 Edit Note: However for an SC400 1UZ-FE application the stock mechanical cooling fan and matching shroud have to be custom fitted to any aftermarket radiator designed for JZ engines.
Old 12-13-20, 09:13 PM
AirioSC300
AirioSC300's Avatar
Default 97 sc300 fan shroud
Will my fan shroud on my 97 sc fit ? Or do you have to buy the supra tt shroud ?
Old 12-13-20, 10:33 PM
KahnBB6
KahnBB6's Avatar
What wasn’t caught in this thread even by myself when I last posted is that while a Supra style aftermarket radiator can be made to fit very easily (has to be raised at the mounts about 1” or so) the JZ shroud it is designed for will not work with an SC400’s 1UZ V8.
People have DIY modified their SC400 shrouds to fit the Supra radiator however.
If you have an SC300 then you can re-use your factory fan shroud (I think the mounting tabs are the same but I don’t remember) or you can buy a Supra NA shroud, Supra TT shroud early type or Supra TT shroud later type.
(TT Supra shrouds have an additional hole for a factory electric auxiliary cooling fan. 1 electric fan hole for the 1993-1996 type and two for the same type auxiliary fans for the 1997-2002 type. These fans were used on both the Supra and very early 2000's Prius).
Last edited by KahnBB6; 12-14-20 at 02:18 AM. Reason: Added info about Supra TT fan shrouds
AirioSC300 (12-13-20)
Old 12-14-20, 01:44 AM
BMGS
BMGS's Avatar
I will forever avoid Mishimoto. I had an aluminum radiator that leaked on me and two thermostats that failed, one resulting in a severe overheating event. Their products are not cheap and the failure is unacceptable for such pricey products.
AirioSC300 (12-14-20)
Old 12-14-20, 02:22 AM
KahnBB6
KahnBB6's Avatar
That's awful. I have had no experience with their radiators but I have heard good reviews about them in the past but that's not a good vote of confidence. I have used two Koyo full aluminum Supra radiators so far (SC300) and I like their quality. Fluidyne used to be a good vendor many years ago but sometime in the last 10-15 years their quality control changed and they don't get good reviews. Denso OEM replacements are good as well if they fit the application.
Old 12-15-20, 06:17 AM
Bimmerbill
Bimmerbill's Avatar
Just a note to help extend the life of your radiator, i have for many many years run distilled water with my antifreeze. I speak from experience and have never seen anyone mention it on Club Lexus. Good Luck
The following 2 users liked this post by Bimmerbill:
KahnBB6 (12-15-20), NYCsc300 (10-12-21)
Deegee
SC- 1st Gen (1992-2000)
10-31-15 02:40 PM
yausito
SC400 / 300 Classifieds
01-23-15 10:52 AM
lengnoou
11-03-09 10:15 PM
scturbo28
06-17-09 06:11 AM
ummagawd
27
04-03-07 11:17 PM
Quick Reply: Mishimoto Aluminum Radiator
