sc400 boosted and over boosting issues
Old 05-15-14, 11:24 PM
kolessc400
kolessc400's Avatar
Default sc400 boosted and over boosting issues
So I have an sc400 1uz v8 with a t3 t4 turbo a 38mm wastegate 8 psi spring and hks bov... I creep from 8 psi and it fludders from 10 14 psi... I have swaped the turbo bov and wastegates 3 times and it still does it... but it works great for about a day everytime I swap the waste gate there is no cracks in the lines I have checked and checked but still cant figure it out
Old 05-15-14, 11:33 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Boost controller?
Old 05-15-14, 11:43 PM
kolessc400
kolessc400's Avatar
None I never put one in yet
Old 05-16-14, 01:48 AM
ArkLaTexSC
ArkLaTexSC's Avatar
Yeah that would help
Old 05-16-14, 08:44 AM
Ali SC3
Ali SC3's Avatar
If the wastegate isn't letting the extra pressure out a boost controller is not going to help.
maybe your turbo is too small or your wastegate is too small.
The bov shouldn't have anything to do with it.
Old 05-16-14, 10:30 AM
mecheng10
mecheng10's Avatar
you could just have bad wastegate placement... that causes tons of creep issues.
orrrr
go up to a 44mm wastegate
(just get the old wastegate flanged chopped off and weld on a new one)
Old 05-16-14, 11:38 AM
Ali SC3
Ali SC3's Avatar
^^ Yes that is correct. going to a larger waste gate will help even if the placement is still bad. if that wont fix it then check placement or just raise the boost to where it creeps via a boost controller and run the 14 psi.
Old 05-17-14, 04:30 PM
kolessc400
kolessc400's Avatar
Well it worked on the first for about 6 mos... then blew the wastegate diaphram... got a new one with bov too and it worked great then started doing it the other day after about a year... then put the new every thing just because... worked for a day and did it again and the last 2 waste gates had no leaks and both are still good but its still doing it and when I did the tutbo I went with a 65 trim and I had a 50 trim originally... im alo just going to replace the lines today too just incase I have a leak I cant see
Old 05-21-14, 12:10 PM
mecheng10
mecheng10's Avatar
bigger turbo +low boost=bigger wastegate needed.
Old 05-26-14, 09:14 PM
Abelo
Abelo's Avatar
I used to have slag from my manifold getting stuck in my wastegate and keeping it stuck open. I had to take it off and clean it out and on the 3rd time it started working fine.
Another thing is that if your turbo was originally internally gated then I know like the holsets you need to weld the internal gate port shut or else you get boost creep or fluctuations.
Old 06-01-14, 01:36 PM
kolessc400
kolessc400's Avatar
So I figured it out the vaccine lines were the wrong size... now I got out fixed its great...o and now I'm working on installing the fic8 again and got the boost controller in
kolessc400
10-04-15 10:42 PM
maddabber0
SC- 1st Gen (1992-2000)
12-13-14 09:12 PM
whomiked
05-19-13 11:43 AM
fordsvtmfl
Performance
17
10-23-08 06:01 PM
JTJerryls400
10-21-05 02:39 PM
Quick Reply: sc400 boosted and over boosting issues
