How to make a clean factory looking BFI DIY
Old 08-24-04, 03:50 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Default How to make a clean factory looking BFI DIY
Thought I would share my Bfi to everyone.
pics #1 & #2 (Below)
Pics of the completed air-box. Basically it looks stock, note the use of the automotive push in trees to secure it and still give a stock appearance. The holes these push into are already in the front radiator-mounting wall so no drilling is required provided you get the correct size push in trees. Also, notice how I cut around the hood rubber bumper mounts to keep the hood fit proper and rattle free.
Attached Thumbnails How to make a clean factory looking BFI DIY-1finished.jpg
Old 08-24-04, 03:52 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 2
pic 2
Attached Thumbnails How to make a clean factory looking BFI DIY-2finished2.jpg
Old 08-24-04, 03:53 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Pic #3 (below)
This is a picture of the top plate. Take care to make a good template out of poster board prior to cutting the plate. I chose to cut mine from black abs plastic (1/16” thick), you can obtain it from about any stereo shop, its easy to work with and looks good. Notice I used door edge guard where it fits up to the air-box, looks clean and provides a good seal.
Attached Thumbnails How to make a clean factory looking BFI DIY-3top-plate.jpg
Old 08-24-04, 03:55 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 4
pic #4 (below)
Here is a picture of the vertical filler panel I made. This too was formed from abs (thicker 1/8”). Make a poster board template again bending it where it needs bend. To do this you must have you air box installed for proper fit. Unfold it and cut out the panel. Now using a heat gun bend the abs to match your pattern. The bottom bolt is actually part of your air box mounting, you will need to sand 1/8” off of the bottom of the air-box mounting bushing to accommodate the panel thickness. The top is mounted to an exiting bracket thru an existing hole using a push in tree. Again no drilling required on your ride. Note use of door edge guard again for the seal.
Attached Thumbnails How to make a clean factory looking BFI DIY-4side-filler-plate.jpg
Old 08-24-04, 03:56 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 5
#5 and #6 (Below)
This is the formed corner that goes underneath the headlight. This is actually the air tunnel for the intake. This is the toughest part of the build. Again I formed it from 1/8” abs plastic. The real dilemma here is to be able to cut your template so it actually sets against the bottom of the head light. It uses the bottom of the headlight as the fourth wall of the tunnel to allow for the biggest amount of air flow. Again, you must use a heat gun to form it to match your template. The sunk in dimple in the corner was done by just heating up the abs and pressing in the car for a perfect fit around stock snorkel mount boss.
Attached Thumbnails How to make a clean factory looking BFI DIY-5formed-corner.jpg
Old 08-24-04, 03:57 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 6
pic 6
Attached Thumbnails How to make a clean factory looking BFI DIY-6formed-corner2.jpg
Old 08-24-04, 03:58 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 7
pic #7 (below)
This picture is of the formed corner installed looking from the inside engine bay out front of the car.
Attached Thumbnails How to make a clean factory looking BFI DIY-7formed-corner-installed.jpg
Old 08-24-04, 03:59 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 8
pic #8 (below)
This is the formed corner installed looking from the right side in. Notice the rivet securing it, this is the only hole you will need to drill. Again, the use of door edge guard for seal and anti rattle. See where the dimple comes into play.
Attached Thumbnails How to make a clean factory looking BFI DIY-8formed-corner-installed.jpg
Old 08-24-04, 04:01 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 9
#9 (below)
Looking from headlight socket in, notice formed flap that directs airflow thru the opening up and over the harness bundle
Attached Thumbnails How to make a clean factory looking BFI DIY-10formed-corner-installed.jpg
Old 08-24-04, 04:02 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 10
#10 (below)
Here is the actual air box modification. I made an aluminum bracket to mount the top lid too. This is aluminum angle purchased from your local hardware store. Cut one leg where you need it to bend and bend it by hand. I riveted it to the box prior to cutting open the hole so I was sure not to cut too much. By the way, the bushing shown on the lower right corner is the one I referenced sanding off a 1/8”.
Attached Thumbnails How to make a clean factory looking BFI DIY-11cut-away.jpg
ScottURnot
Super Moderator
ScottURnot's Avatar
Default pic 11
#11 (below)
This picture is a little difficult to follow at first. It is looking in the front air dam opening right below the tag mount. You remove the two stock fasteners to allow the plastic air director to be pulled down to open up a sort of air scoop in the front of the car. I used some aluminum tube that I threaded to Allow me to bolt to the plastic air shield so again no hole drilling was required. Tensing holds it up against the bushings. I am fortunate to have a 97 so I get the additional benefit of the factory grill bringing in additional air.
Attached Thumbnails How to make a clean factory looking BFI DIY-12front-air-scoop.jpg
Old 08-24-04, 04:08 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Default last pic 12
#12 (below)
This is the last picture. It’s hard to see it good from a picture but here is an attempt. If you remove the filter (I used a K&N) and look out the front this is what you see. Notice how open it is, plenty of air getting in here!
Later,
Scott M.
Attached Thumbnails How to make a clean factory looking BFI DIY-13looking-out.jpg
Old 08-24-04, 04:31 PM
MrJohnTan
MrJohnTan's Avatar
Thats a nice setup.
I have to give you the award for the cleanest BFI setup to date.
Good write up also.
Old 08-24-04, 05:28 PM
Twirl
Twirl's Avatar
Thumbs up
great write-up!!!!!!!!! i love your work, i commend you on your attention to detail, im sure your noticed nice gains from this.
Old 08-24-04, 07:47 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Originally posted by MrJohnTan
Thats a nice setup.
Good write up also.
Thanks for the positive feed back and the compliment.
Later,
Scott M.
Quick Reply: How to make a clean factory looking BFI DIY
