Sc 400 shift solenoids issue
Old 04-22-14, 08:51 PM
mulcryant
mulcryant's Avatar
Default Sc 400 shift solenoids issue
Now I think ive narrowed it down to this, i haven't dropped the pan but the atf fluid is doesn't seem to have much of anything although i haven't taken off the pan to see if the filter is clogged or if the magnet has caught anything the car seems to shift fine
heres my cars second issue and i know this because of the previous owner (not the one i bought the car from but the one who left his paperwork in the car explained to me)
the car will not start if you cut it off and then try to start it again
period
wait 5 minutes every time and it will cut right back on
the guy has countless receipts of stuff that has been replaced by a reputable shop
heres how it happens every time
the ecu i believe thats how its spelt? or ecm has been replaced as if it was culprit cost nearly 1k for it and that still didn't fix it but anyways onto what the car does (this issue has nothing to do with the tranny but it doesn't help that i cant restart the car right away sometimes)
go to the car unlock get in and drive off
first gear ok
second gear ok
third gear ok
fourth gear ehhh not until 4k rpms but it will still go in
ive been able to push the car up to 80 but after whatever gear i get it up to its just goes into a neutral limp mode
cut the car off, cut it back on and drop it back into drive and it will go again just fine for a another maybe 1/4 then do it again
if i let the car just sit there and warm up and try and do put into gear after letting the car warm up per say it won't go into gear, turn it off back on whoala
sometimes ill have to wait the 5 mintues but it works like magic every time
all the shifts go in at low rpms and high rpms so my guess is shift solenoids
also my speedometer did not work and now it did? randomly i guess?
i was searching in the trunk for the hinge wire and i couldn't find it does anyone have a picture of it by chance?
Old 04-23-14, 09:04 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
If your speedometer is spotty, that would be the VSS.
As to your other issue, it could be a slow shift solenoid, do the issues go away when the tranny is cold? Failing tranny cooler?
I was having a similair problem and after a bunch of "dropping pan poking around at the VB, moving this, replacing that, " I found out that the entire issue was an ATF thing.
Make sure to
-Fill the transmission with ATF while the car is at idle
-Check fluid level when up to temperature, and at idle.
How many miles?
Old 04-23-14, 09:47 AM
DriftSCZ30
DriftSCZ30's Avatar
Had the same thing happen to me in my SC400. Ended up removing the trans off it and now I'm swapping a KA24DE Manual trans into it.
Old 04-23-14, 06:43 PM
mulcryant
mulcryant's Avatar
i checked the cars codes today i got code 24, 42, and 71
42 is the speed sensor but i doubt this would be causing it to shiftout to neutral while riding normally
i had to drive the car home 13 miles and i made it in about 4 hours but i made it waiting 5 minutes in between for the alarm
Old 04-24-14, 10:19 AM
mulcryant
mulcryant's Avatar
bump with more info, well i learned this today the ATF radiator beneath the drivers side headlight is bent back and so are the lines
i think this may be the cause of it
i do believe this is for the ac?
Old 05-02-14, 04:55 AM
mulcryant
mulcryant's Avatar
well one i feel dumb about the whole atf radiator my bad
but on the good news
4 quarts of new toyota type II fluid
a new filter (for the whinning noise that transmission was making)
i got new shift solenoids in a kit, i did not however install the lock up as i didn't feel it was necessary
but after allllll that!
SHES RUNS!!!!!
Thank you lexus community for all your help
jayjay1992
20
11-10-16 08:08 PM
VIP40092
08-30-15 11:14 PM
Suprub93
08-19-13 05:16 AM
trufanatic
10-31-08 08:33 AM
almariam
03-10-03 07:18 PM
Quick Reply: Sc 400 shift solenoids issue
