1jz vvti sc400 no check engine light
Old 04-12-14, 02:06 PM
estomax
estomax's Avatar
Default 1jz vvti sc400 no check engine light
Hey Guys,
i am on the home stretch of wiring in my SC400 1JZ VVTI conversion and have one strange problem. i can't get the CEL output of the ECU to come on. The CEL pin to the cluster is wired from the ECU to pin IK2-9 which what all the diagrams point at, but the VVTI ecu is not turning the light on. I believe (based on the wiring diagrams) that the ecu is a sinking output which means it grounds the CEL to trigger it, can anyone confirm? i am getting 12V coming down to IK2-9 so i know it is coming through the gauge cluster, but it is just not grounding in the ECU. i should try just grounding that pin to see if the CEL turns on on the cluster too.
i did get the car to fire up for the first time today though!
Old 04-17-14, 08:28 PM
estomax
estomax's Avatar
anyone have any input for getting the CEL output working on a vvti ECU?
Old 04-25-14, 08:17 PM
estomax
estomax's Avatar
anyone here have a 1jz vvti with the CEL working to confirm that the CEL output is not different from sc300/400 for the gauge cluster?
Old 04-27-14, 04:02 PM
estomax
estomax's Avatar
well i figured it out. i somehow decided EGW is the right pin for the check engine wire, instead of W, which is what it should be. one of the spreadsheets i found here guided the CEL to be hooked to that, another said to ECU connector H pin 3 which is W, which is the CEL output.
for anyone's references the EGW is for exhaust gas temp warning light on dash (if your car has one).
all good now, only got code 47 after connecting battery, for the traction control throttle position since i ripped all that out. time to figure out a resistor mod for that.
Old 11-16-15, 08:15 PM
Kris9884
Kris9884's Avatar
Hey I hope your still around the forums, I've got some questions. You've got PM.
kez
SC400 / 300 Classifieds
06-19-18 01:38 PM
2jzcoupe
12
12-10-16 03:54 PM
Dtaylor3
SC- 1st Gen (1992-2000)
09-22-15 07:34 AM
jintei
31
09-11-13 02:44 PM
soarin87
04-03-13 04:34 AM
Quick Reply: 1jz vvti sc400 no check engine light
