loss of power running rough
Old 03-30-14, 12:16 AM
v8hterz
v8hterz's Avatar
Default loss of power running rough
Hey everyone my name is ethan i have a 92 lexus sc400 just bought and love the car but week later since i owned it randomly had a huge power loss and was running really rough i put a test to it said 5 piston missfireing so changed plugs wires solved that but still running same so one day smelt something and hurd from my exhaust something weird so looked under cats were Orange hot so i took them off they were shot and cloged up so i gutted them and threw a pipe in it welded it in and bolted it back up helped gave it most of the power bavk but still not all of it so idk what it is and dont want spend hundreds on it if its a simple problem maybe then cleaned the tb and sea fomed it clamped all vacuum lines still same but i have 3 codes ones 02 went on when i gutted the cats and iat. Sensor idk where that is idle air temp i think and the maf sensor because i unpluged it because was shot but getting new one on tuesday but idk if thats the problem the maf because never used to beout tell the other day
Old 03-30-14, 10:09 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Please use proper punctuation when writing. It makes the thread much better to read and understand.
I also moved this to the proper forum section.
Old 03-30-14, 10:23 AM
SexCoupe
SexCoupe's Avatar
sounds like coil packs... you have 2 one directly in front of the plenum the other is mounted sideways on the driverside about 12 inches away.
Old 03-30-14, 05:13 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
While the car is running, unplug the coils, one at a time. Probably your issue. If not, your ECU took a dump.
Here is the helpful sticky to everything you need to know. https://www.clublexus.com/forums/sc-...tart-here.html
coldspring
06-09-22 08:21 AM
v12mac
IS - 1st Gen (2001-2005)
07-11-15 10:53 PM
kminev
SC- 1st Gen (1992-2000)
01-14-10 04:52 PM
1993Ls400s
13
10-02-08 12:36 PM
Conceptvip
12
03-23-06 01:08 PM
Quick Reply: loss of power running rough
