95 sc300 2jzge vvti swap
Old 03-26-14, 06:27 PM
crichsc300
crichsc300's Avatar
Cool 95 sc300 2jzge vvti swap
i have a 95 sc300 and i just picked up a 2jzge vvti gs300 motor with ecu end engine harness wondering if anyone could give me some info on doing this swap as far as wiring or is it a direct swap if i have the 98 sc300 2jz vvti engine harness
Old 03-26-14, 09:18 PM
Vrank
Vrank's Avatar
Do you have the key that came with that ecu? If not you're gonna have to spend a few hundred bucks on getting a key programmed. Then after that you'll have to acquire and wire a transponder amplifier to pick up the keys signal so the car will start. Be a boss and run it on a jzx100 ecu and maf with 440s with an early model sc throttle body. That way you can slap a turbo on later and you're ready to go tuned for boost from the factory. Don't get retarded with the vvti ge engines and boost or it'll blow up. Have fun.
Old 03-27-14, 07:09 PM
crichsc300
crichsc300's Avatar
naw i don't have the key but i can get one programmed no prob... at this point i just wanna know exactly what I'm gonna have to do to get the motor to work in my car I've been reading a lot of dif things everyone has something dif to say its kinda confusing me i just need a straight forward answer if i use the sc300 98 vvti harness what all will i have to change on the harness its self to get the motor to work with my sc which is a 95 non vvti... when it comes to building the motor i have a secondary block I'm building and I'm gonna do some top end work as well stand alone the whole 9 I'm not a rookie in the toyota lexus world just never did the wiring part of the deal before so if you have info on just how to get it going stock motor that would be perf thanks
Porter92
12-30-13 01:55 PM
WadeLovell
05-21-12 10:21 AM
SC51
179
06-09-11 07:05 AM
wagomaniac
09-20-09 07:28 AM
thombiz
12-17-04 03:21 PM
Quick Reply: 95 sc300 2jzge vvti swap
