Need help with power steering
Old 03-21-14, 08:22 AM
Marckussb
Marckussb's Avatar
Default Need help with power steering
Hey guys I just picked up a 1jz swapped sc300. When I got it the power steering did not work at all. I added fluid and it works a little better, but it groans quite a bit when I turn.
I also have a leak and can't seem to find a replacement hose and for some reason the routing seems off?
Anyone know if this is a high pressure hose and where I can get one and if the routing is correct?
Thanks
Old 03-22-14, 07:09 AM
Vrank
Vrank's Avatar
stock sc300 high pressure power steering line will work, or driftmotion sells a kit to go to stainless braided that makes routing less gay.
Old 03-24-14, 06:13 PM
Marckussb
Marckussb's Avatar
Thanks guys. Does that routing look correct though? And what's that two port valve by the pump?
I added fluid and bled the system, but the steering is still heavy and it's almost as if the PS doesn't work when the car isn't in motion.
eknine9
09-04-16 10:48 AM
Diegolazo5
SC- 1st Gen (1992-2000)
06-19-15 01:06 PM
jessev1
09-14-11 08:35 PM
socalturbo
01-12-10 09:13 AM
fjmaze
02-21-08 10:13 PM
Quick Reply: Need help with power steering
