lc-1 wideband install help
Old 03-11-14, 05:41 PM
wirelesstj
wirelesstj's Avatar
Default lc-1 wideband install help
i wired in the wideband according to the instructions. all the grounds lead to one plug and the gauge is getting proper power. the led and gauge keep blinking and wont read out the afrs. should i have wired 2 grounds instead of all grounds leading to the same plug?
Old 03-12-14, 08:30 PM
1997Soarer
1997Soarer's Avatar
Try that. I've noticed that some devices have issues when they share a common ground with other electronics. Since you've said it came with 2 grounds, that usually means they should be grounded in 2 separate places.
Old 03-13-14, 08:23 AM
Ali SC3
Ali SC3's Avatar
some devices use a sensor ground and a regular ground, they are different. I would look up the actual instructions.
Old 03-14-14, 01:34 PM
stockhatch
stockhatch's Avatar
I always ground my LC-1s to a common point with no issues. I think something else is going on. Did you do all of the 1st boot and calibration steps?
Old 03-18-14, 08:56 AM
wirelesstj
wirelesstj's Avatar
i think its because i was grounding the calibration wire as well, i think that was my problem. im gonna re wire it when i get my soldering iron back and see if that fixes it. im sure it will
onejapman
08-23-08 01:16 AM
OneJay
18
05-20-08 06:45 PM
Josey
Suspension and Brakes
05-28-05 06:10 PM
Kizoku
05-14-02 05:27 PM
Quick Reply: lc-1 wideband install help
