Oil filter, buying one at Lexus vs Toyota dealer . . . .
Old 07-30-14, 08:37 AM
t2d2
t2d2's Avatar
Vrank, good to know. I've never used Napa Gold filters, but I've seen them recommended a few times on various forums. I was planning on going with Toyota filters to eliminate the guesswork of what aftermarket item is up to OEM spec, but if the Napa Golds fit the bill, they're a little bit cheaper and more convenient for me to pick up, so I might as well go that route. FIL 1348 is the part # for the SC400, BTW.
Old 08-03-14, 06:55 AM
Waxologist
10th Gear
Waxologist's Avatar
Originally Posted by SpooledSC
We (Toyota dealer) buy those filters by the cases nearly every day and I can assure you that is a false statement. The D1 filter was superceded by the G1. If you find D1's it is old stock.
G1 filters are made in the US. D1 filters are made in Thailand. If you look in the D1 filter you will see a check valve clearly visible. A G1 doesn't have a visible check valve. If you look at the G1 box it tells you what engines it's supposed to be used on. You won't see a 2jz on that list. That being said, both filters are F-08 filters so they will both work without problem. If you look up a filter in the Lexus catalog, It says to use the D1. D1s aren't old stock just different manufacturers. D1s are shipped in boxes of 10' and G1s are shipped in boxes of 12. I personally use D1s just because that's what they recommend.
Old 08-03-14, 09:41 AM
ogtony19
ogtony19's Avatar
It says JZ series on the front of the G1 box. Only differences are the D1 is bought in bulk and comes prelubed on the o-ring from the factory.
Old 08-03-14, 03:14 PM
Waxologist
10th Gear
Waxologist's Avatar
I see. I didn't notice that on the filter box.But, you're not correct on the bulk thing thou. I will post a picture of the the boxes they come in tomorrow.
Old 08-03-14, 07:27 PM
CatManD3W
CatManD3W's Avatar
Get the 90915-YZZD3....Which is the V8 tundra oil filter.....it works just fine and is much bigger than the one that you are showing
Old 08-04-14, 09:36 AM
Waxologist
10th Gear
Waxologist's Avatar
G1s are ordered in quantities of 12 while D1s are ordered in boxes of 10. It doesn't matter how many toyota orders, they will just be in boxes of 10 or 12.When I looked at the 2 filters, the G1 is actually the one with the visible check valve.
Attached Thumbnails Oil filter, buying one at Lexus vs Toyota dealer  . . . .-image.jpg
Old 08-04-14, 11:52 AM
oldManTan
oldManTan's Avatar
the paranoia is strong with these folks lol
Old 08-04-14, 04:42 PM
ogtony19
ogtony19's Avatar
I'm a tech at a Toyota dealer here in KC, and when i mean bulk i mean when the parts department orders filters they order them by the hundreds maybe thousands. That is bulk, not by how many are in a box.
And the D3 is the filter that the UZ family of V8s take. I think only difference is that it has more oil capacity than the D1/G1
Old 08-05-14, 01:50 AM
Aron9000
Aron9000's Avatar
I guess next time I do this I can just ask for an oil filter for a 1993 Toyota Supra, non-turbo motor, just to make things simple.
Old 08-05-14, 03:19 AM
Waxologist
10th Gear
Waxologist's Avatar
I understand what you mean by bulk. I'm in South Carolina. This is the south eastern region for Toyota. I do stock orders for Toyota all the time. I always order filters in bulk. It's not because I have to, it's because it doesn't make sense to order 10 or 12 filters when we sell hundreds of filters in a day.
CaptRog21
02-12-20 01:24 PM
ryanSC300lover
04-17-18 03:34 PM
vesnyder
16
12-10-07 10:04 PM
kutscher
Maintenance
17
11-17-04 02:04 AM
Jmai22
Maintenance
58
11-09-04 06:51 AM
Quick Reply: Oil filter, buying one at Lexus vs Toyota dealer . . . .
