help
Old 03-02-14, 06:02 PM
soarer1988
soarer1988's Avatar
Default help
I am looking for some 1 to fix my speedo and climate control who can do it the clock in the speedo dont work the climate control looks like a ink splat on and on the speedo just the #s light up help this is pissing me off lol
Old 03-02-14, 06:44 PM
ArkLaTexSC
ArkLaTexSC's Avatar
All common issues, should use search for more in depth answers.
Speedo...gotta replace bulbs, easier said than done, happens to all SCs. I'm just going to order a custom panel. As for the clock, no clue.
CCU, replace LCD. Again easier said than done.
Old 03-02-14, 07:58 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
If you're use to soldering, you might give a try at replacing the LCD yourself on the climate control. Part is 20 bucks, just very small solder points to dits with. Search around, there are services everywhere.
Old 03-04-14, 07:02 PM
soarer1988
soarer1988's Avatar
ok thanks guys
Old 03-05-14, 06:11 PM
xiaolong
xiaolong's Avatar
in the meantime, give your dash a couple smacks. sometimes that gets the needles moving.
NCDUB
03-28-09 10:15 AM
skotter
03-20-09 01:53 PM
3rdelement
03-25-05 10:01 PM
dkny_112
SC- 1st Gen (1992-2000)
08-05-02 06:30 AM
Quick Reply: help
