Helppppp
Old 02-01-14, 08:37 PM
riobanks
riobanks's Avatar
Default Helppppp
Ok so my lexus O/D light blinks? On top of that the car has a very slow take off. The RPMS goes up to about a 3 and stays at 40 if i go any faster it goes all the way around like to the 5. I can not tell if it changes gears or not because the engine does not sound like it rev. Also when i stop or sit in park at times the car shakes a little like you think its about to cut off.. Need a new transmission and tune up? or could trans make the car act this way?
Old 02-02-14, 04:37 AM
TonyFrench
TonyFrench's Avatar
Which engine ? 1jz, 2jz (ge or gte), 1uz ?
Old 02-03-14, 04:27 AM
riobanks
riobanks's Avatar
not sure standard? 6 cyl
Old 02-03-14, 08:07 AM
riobanks
riobanks's Avatar
Default hellpp
Ok so the mechanic just told me that its 90 percent sure its not the transmission. he thinks its the ecu because it was replaced before about 8 years ago
Old 02-03-14, 08:58 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
...then have it rebuilt or replaced. (Pro tip...don't buy it from the dealer)
Old 02-03-14, 09:08 AM
SCereal
SCereal's Avatar
I remember reading a thread either here or supraforums about the cause of the OD light blinking but I don't remember what it was. Sounds like its not shifting at all and stuck in a gear. trying another ECU is simple enough but in the meantime, search here and supraforums and see what you can dig up.
Old 02-03-14, 09:25 AM
OG Dada
OG Dada's Avatar
O/D light blinking means there's a problem with one or more of the solenoids in the transmission, there's 4 total. You can buy a set somewhere in the internet universe for like $350 or something last time I checked. While you're at it, you can change the transmission fluid strainer and flush the oil.
Giddyup08
09-11-18 04:40 AM
My03Tundra
02-20-15 01:27 PM
moving2
10-05-14 11:08 PM
tarponman
07-13-09 01:53 PM
Fizzboy7
12-27-08 01:40 PM
Quick Reply: Helppppp
