Is the Sc4 cluster harness or body plugs identical to the Sc3/Soarer?
I'm finishing the last of my 1jz swap and lastly I just need to finish my wiring, instead of ripping out my 2jzge harness and rendering my car in inmobile till the 1jz running. I was thinking maybe I can go to the junkyard and find a SC 400 harness to use instead so i can move around and do not have to cut my wires.
so my question is, is the sc400 cluster plugs or body plugs exactly the same as the SC 300/ soarer? do they color match exactly like the sc300 wires? or is the sc400 harness and tirely different? looking at some pictures of a sc400 cluster harness it actually looks identical.
So does anyone know if this will work? Im going to rip one out regardless and see what i can come out with, it it dosnt work then il just cut my ge plugs
Heres the plugs im talking about
Pretty sure. Going by color is stupid though, no matter what. Go by circuit via continuity. You wanna chase gremlins because you were too lazy and decided to use color, be my guest, but the appropriate effort up front will yield you the best results.
If you have a soarer harness with your 1j, the one pictured, then its a waste of time even getting a 400 harness. Everything you need should be there.
Sorry the picture shown is a 1jz harness that i found on google. My 1jz soarer is missing those 4 of the 5 body plugs.
But i was just wondering if there identical to the sc4
Heres my harness
The 4 plugs are missing so instead of usuing mine of the sc3 ge, i was thinking of geting spare connectors to use so i can stil drive my car til i rip out the ge , problem is i only have access to a sc4
Heres my harness
