92 sc300 with 2jzgte swap.. Gauge cluster prob
Old 11-10-13, 08:24 PM
2jz610
2jz610's Avatar
Default 92 sc300 with 2jzgte swap.. Gauge cluster prob
I can't get my mph, tach or temp to work on dash.. I am using a v160 6 speed trans.. Any suggestions..
Old 11-11-13, 06:56 PM
2jz610
2jz610's Avatar
I guess I should
Also
Mention I'm running a aem computer... I know the v160 has a speed sensor on it if I'm not mistaken soo I'm pretty sure I have to hook up the mph gauge threw that.. Coolant ill have to hard wire I guess.. Gas as well.. But rmp I'm not sure of..
Old 11-12-13, 12:02 AM
soarer13oy
soarer13oy's Avatar
it should all be on the body plug. I cant quite remember which one to be exact but im sure its probably not wired into the body plug.
Old 11-12-13, 05:18 AM
stockhatch
stockhatch's Avatar
^^^^^^^ what he said. Who wired the swap? It could get really messy depending on what was hacked out or forgotten.
Old 07-29-14, 12:12 PM
2jz610
2jz610's Avatar
Broadway performance and I still can't fig it out blah. Everything is plugged in that I can see but I haven't taken dash off n don't want too.
Old 07-29-14, 01:36 PM
99SC42
gte & na-t
99SC42's Avatar
^^ Who did the wiring?
Old 07-29-14, 03:49 PM
hmhatch
hmhatch's Avatar
You don't need to remove the dash. Everything is down at the passenger side kick panel ecu area.
Old 07-29-14, 06:46 PM
CatManD3W
CatManD3W's Avatar
Start on post #83
This should help to understand what wires control functions on the car....
https://www.clublexus.com/forums/per...de-easy-6.html
There is alot of other useful information on this thread Gerry made for CL community....I personally built my own wiring harness by using this thread.....
Old 07-30-14, 09:03 AM
soarer13oy
soarer13oy's Avatar
http://wilbo666.pbworks.com/w/page/4...odyLoomPinouts
Old 10-09-14, 09:50 PM
2jz610
2jz610's Avatar
Figured it out. Ended up being several dash harness grounds.. So everything works now except mph gauge. But that's due to not setting up v160 sensor wiring yet.. Thanks for everyone's help
Sc1349
05-06-15 11:58 AM
acidreian
01-15-14 05:32 AM
robsidewz
04-21-12 07:41 AM
Shinbone
11-26-08 07:54 AM
Quick Reply: 92 sc300 with 2jzgte swap.. Gauge cluster prob
