egr delete can't get the resistor right cel is still on
Old 10-29-13, 05:13 PM
Crazedshif
Crazedshif's Avatar
Default egr delete can't get the resistor right cel is still on
Installed the egr delete kit from lextreme. No instructions came with the kit and every time I call and ask for them to email me some instructions they say they will and ignore me 3 days in a row so far. Not buying anything else from lextreme not pleased with the customer service. Got everything done except I cant gey cel to turn off. I have it hooked up to the the temp sensor wires that were next to the egr valve. Where is it supposed to be?
Old 10-29-13, 05:40 PM
Ali SC3
Ali SC3's Avatar
Im not sure that is something they would tell you but its covered in the forums, sounds like you have the right wires, are you sure you are using the right resistor?
Old 10-30-13, 12:23 AM
Boergy
Boergy's Avatar
HY!
i installed in my 97 SC400 a 10k-Ohm resistor instead the sensor ( near the ECU, or you can do this by the plug) , no problems more
yauny
02-07-17 06:31 PM
mitmaks
10-19-15 12:28 PM
t2d2
07-03-14 07:00 PM
kigkug
04-11-12 08:13 PM
Quick Reply: egr delete can't get the resistor right cel is still on
