Putting 2jzgte engine back in car have sensor and flywheel question
Old 09-22-13, 03:48 PM
zrs6v4
zrs6v4's Avatar
Default Putting 2jzgte engine back in car have sensor and flywheel question
I have a 2jzgte swapped sc300. The old gte engine spun a bearing so i ordered a new auto swap for another engine. I have a couple of questions from swapping parts from my old engine to the new one.
First (i know this is dumb) is that i took the flexplate off of my new engine. There was a spacer between the flexplate and where is bolted into the block. Im using a w58 5-speed, so when i bolt the flywheel on i will not use the spacer, correct?
Second there is a sensor on the block that is different and im not sure which one to use. I tokk the one off of my old blockand snapped a pic of the difference:
Thanks
Old 09-22-13, 04:41 PM
6SOARER
6SOARER's Avatar
No spacer.. Bolt flywheel directly on the crank
That looks like the oil pressure sensor in pic#2. Use whichever one your harness is going to plug into.
GL with the install!
Old 09-22-13, 05:51 PM
soarer13oy
soarer13oy's Avatar
+1 i would assume you would use your old sensor since it was on your old setup.
Old 09-22-13, 06:03 PM
zrs6v4
zrs6v4's Avatar
Yea i had a couple of rigged sensors and i wasnt sure if this was one of them.
Old 09-23-13, 08:37 AM
Ali SC3
Ali SC3's Avatar
the on on the block looks like the normal one, not sure about the one in your hand, but the advice of using whichever fits your harness is good advice as long as they both thread in the hole on the block.
Old 09-23-13, 08:46 AM
Elevated
Elevated's Avatar
I'd personally convert to the newer style sensors and clips just because they're newer/easier to come by. They all work the same, newer is just usually better/more convenient.
Old 09-23-13, 12:55 PM
zrs6v4
zrs6v4's Avatar
Yea im gonna swap it over, ill have to break the one on the block to get the awkward 24mm 12 point on it
Old 09-23-13, 02:54 PM
Ali SC3
Ali SC3's Avatar
a large vice grip will also do the job.
Old 09-23-13, 05:03 PM
zrs6v4
zrs6v4's Avatar
You cant fit it in there unfortunately
Sett26
05-09-15 06:52 PM
anx4evr
13
09-19-13 08:48 PM
BRIANxJDM
GS - 1st Gen (1993-1997)
01-11-10 02:11 PM
onefast350
06-20-06 08:33 AM
MGS4
IS - 1st Gen (2001-2005)
04-09-01 08:51 PM
Quick Reply: Putting 2jzgte engine back in car have sensor and flywheel question
