SC400 short circuit
Old 09-07-13, 11:57 AM
ashtray
ashtray's Avatar
Default SC400 short circuit
Any ideas where my 1992 sc400 might have a short? The car is tip top but she keeps draining batteries even with a new alternator. We've gone through several batteries and my mechanic could use our help. Any thoughts are appreciated. Could it be the fuel pump ecu?
Old 09-07-13, 06:13 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
How fast is the battery draining? 2 weeks without any use is the usual for SC's batteries to drain, with an alarm system.
Old 09-07-13, 07:48 PM
ashtray
ashtray's Avatar
About 2-3 days. It gets driven daily. Completely stock no alarm.
Old 09-07-13, 08:11 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Could be a number of things then. From ECU to Starter magnetic switch.
First I'd check would be engine grounds. Look for any corrosion on the terminals. Test the battery with an ohmmeter for grins to make sure it isn't an output issue. Don't know how short term it can cause as quickly, but if your PS fluid leaks abundantly that could be ruining your Alternator. Fat chance tho.
Here is a helpful thread. More of a long-term drainage though.
https://www.clublexus.com/forums/per...g-battery.html
GL.
Old 12-31-13, 07:04 PM
bigwhite
bigwhite's Avatar
This is the closet thread to post the fact that yes my tip-top SC400 will drain a battery in 2-4 weeks in the winter.
Caanon
08-01-15 09:35 AM
adc27
SC- 1st Gen (1992-2000)
11-18-14 07:43 AM
Biddles
03-18-13 05:08 PM
booramey
07-31-12 03:57 PM
BOBSOFI
06-20-07 09:41 AM
Quick Reply: SC400 short circuit
