Help with my oil light.
Old 08-29-13, 06:09 PM
Rvo7632
Rvo7632's Avatar
Default Help with my oil light.
I have 96 sc300 with a 2jzgte swap. Everything seems to work right. But my oil light on my cluster comes on after about a min of starting the car. I check oil and it is full?? Plus my stock temp gauge on cluster isnt working also. The last owner could never figure it out or. Never got around to it. So he end up installing a aftermarket one on the tripod. Can somebody help me figure where to start
Thanks everyone
Old 09-02-13, 06:46 PM
Rvo7632
Rvo7632's Avatar
Anybody have any thought on this?
Old 09-02-13, 07:32 PM
soarer13oy
soarer13oy's Avatar
Im assuming the wire from the sensor to the body plug is incorrect. For the coolant temp gauge you need to ground a wire at the body plug. If you do a search for the 1jzgte swap coolant temp fix you should be able to find the thread and fix.
Old 09-03-13, 04:46 AM
Vrank
Vrank's Avatar
For the coolant temp, if you did it properly it grounds through the harness to the intake. The other wire goes from the one wire sending unit to the dash via body plug ik1 iirc. Double check that though. Also, which oil light. The level one with the water looking mark and oil thing or just oil thing. Because if its the 2nd one you might wanna worry about pressure.
Best case scenario some body function circuits need to be verified and re-routed to their correct location. I'd start with makin sure check engine light isn't wired to oil pressure.
Old 09-07-13, 03:02 PM
Rvo7632
Rvo7632's Avatar
Hey guys. Haven't had a chance to read your post till now. But thank you. Now i know where to start with this problem. And by the way i think the oil light is the first one that ur talking about, with the water light? Not sure will check and get back. But ill be checking the coolant light sometime next week. Just been super busy with work and school.
ericsan13
RX - 4th Gen (2016-2022)
14
03-20-19 05:02 PM
FUZCO
RC - 1st Gen (2015-present)
11-17-15 05:59 PM
luckyis300
IS - 1st Gen (2001-2005)
04-03-12 09:47 PM
soardrft
07-16-09 06:39 AM
Quick Reply: Help with my oil light.
