1/8 throttle jerking, 2800rpm power jump
Old 08-26-13, 05:19 AM
Fubari33t
Fubari33t's Avatar
Default 1/8 throttle jerking, 2800rpm power jump
Two issues, might be related, might not. 1/8 throttle(cruising) jerking and bucking under 2k rpms. Must cruise at 60 to keep it fdom bucking. Must be in acc, or no throttle to keep it from acting up. Also. There is a huge power jump once RPMs reach 2800k+ not aware of cam work on car, also my first 1uzfe, this is a 92 sc400. So no VVT. Cleaned tb, iac seems to be working. Cant pull it yet. Fresh tune up. Anyone have these issues?
Old 08-26-13, 07:41 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Check yout TPS with an ohmmeter and feeler gauge. (there is a thread on that). Could also be the MAF, and the o2 sensors.
Old 08-30-13, 06:14 AM
Fubari33t
Fubari33t's Avatar
Did the test on TPS, IDL1-E2 @.65mm Should be infinity, but I get .1. So it looks like I'm getting a TPS. Still gota test MAF,
Old 08-30-13, 06:16 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Yeah, should read "open circuit", or infinity. Try replacing that with a known good one and see if that fixes it. Also, the TPS might need setting with an ohmmeter and feeler gauge. Some of them require calibration. Not to hard.
If TPS doesn't do it, the o2 sensors would be my guess.
ThomasGS4
Performance
33
03-06-13 01:45 PM
wallyman42
01-07-12 01:14 PM
NaturalJZ
08-24-11 10:17 PM
jrckelley
12-09-07 09:32 PM
Quick Reply: 1/8 throttle jerking, 2800rpm power jump
