Sc300 na-t stutter at 5k rpm
The Car ran great broke my clutch and it sat for A week or so, put it back together and it started stuttering when in boost above 5k rpm,s. I just bought the car it has 70mm turbo at 11psi arp head studs full apexi exhaust aem stand alone version 1, Nology wires aem fpr. That's about all I know about it I'm lost at what could cause this. i checked all my vacuum and for boost leaks can't find any afr looks good. hoping some one can help me out.
11 psi does not get hot enough to "heat cycle" a range 8 plug which is how the spark plug clean itself.
when your plug is too cold you get fouling. stock GE plugs are like a 5 range, and a stock TT is a 6 range which would work for your psi, but a 7 works better when BPU or single turbo and is what most run. if you were closer to 20 psi you would want to try out a 8 range.
