SC300 differential backlash
Old 06-13-13, 07:58 PM
INTIMAZY
INTIMAZY's Avatar
Default SC300 differential backlash
Putting together my 3.3 rear with Kaaz SuperQ LSD. I was searching around for SC/Supra recommended backlash measurements for the 200mm diffs. Pinion depth should be fine since I am using a SC430 pumpkin.
Anyone know what the proper backlash should be???
Old 06-13-13, 09:17 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
That's not an easy thing to get right. Best I can suggest is looking in the MKIV TSRM:
http://www.supracentral.com/foundation/mkiv-tsrm/
Edit: Try section SA-62 but it focuses mostly on the 220mm 6-speed differential. The backlash for 200mm NA/TT Auto diffs should be in that section.
Old 06-13-13, 09:53 PM
INTIMAZY
INTIMAZY's Avatar
Thanks!! Exactly what I needed.
.0031 to .0051 in case someone wants to know for future reference.
Old 06-13-13, 10:11 PM
Bflatsharp
Bflatsharp's Avatar
thanks for the link.
Old 06-14-13, 01:09 PM
KahnBB6
KahnBB6's Avatar
Sure, and thanks for finding it in there Intimazy
oldManTan
SC- 1st Gen (1992-2000)
08-06-14 06:16 PM
lbz_s14720
10-03-07 12:55 PM
reamemiya
06-19-05 12:54 AM
elhalisf
06-29-03 10:19 AM
Quick Reply: SC300 differential backlash
