How easily should a driveshaft insert into the rear of the transmission?
Old 06-07-13, 02:04 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Default How easily should a driveshaft insert into the rear of the transmission?
A bit of a head scratcher here. I bought an R154 front driveshaft supposedly for an MKIII a couple of months ago but since it looked awfully similar to a W58 SC driveshaft I became concerned I had been sold the wrong part. I took this over to a shop that had an R154 and it was confirmed to be a Soarer or Chaser R154 front shaft, hence the confusing shape.
However after cleaning the input side of the shaft end and attempting to test insert it into my R154 it really doesn't want to slide in. I don't believe the splines are different at all. It just doesn't go in more than an inch and I don't feel comfortable forcing it.
This could be due to surface rust that I've been in the input end but I've been using a small plumber's wire brush to get rid of that.
Could this also be as simple as needing some grease in there to allow it to slide in?
Old 06-07-13, 04:32 PM
soarer479
soarer479's Avatar
Your going about it the right way with the wire brush, there should be a little resistance but once the splines are lined up it should slide in with just a few lbs of force but don't be scared to put the who done it on it.
Old 06-07-13, 06:28 PM
Cleanshots
Cleanshots's Avatar
lube it a little bit it needs to slide in pretty nicely if you shove it and you are sweeping the ground with the transmission u r doing too much lol
Old 06-07-13, 08:17 PM
KahnBB6
KahnBB6's Avatar
Hmm. Okay guys. I'll give it a second try tomorrow. What grease do you recommend for the inside of the shaft? The Mobil1 pink stuff? The transmission is currently on a dolly in my workshop. I'm just test fitting parts and converting it for installation right now.
Old 06-07-13, 09:20 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
MOBILE 1 is fine or any synthetic grease. Use break cleaner to clean up before applying any grease. Should slide right in.
Old 06-08-13, 09:53 AM
KahnBB6
KahnBB6's Avatar
Okay, thanks! I'm going to use some break cleaner and then try the mobil1 grease once it looks good enough. I'll let you guys know if it works.
Old 06-08-13, 09:03 PM
KahnBB6
KahnBB6's Avatar
More wire brush scrubbing, brake cleaner and a little bit of 5W-30 motor oil on the splines of both the transmission and the driveshaft made for a perfect fit! Thanks for the help, guys!
The final thing is that, while the shaft definitely goes in quite a ways now, the collar end of the driveshaft and the collar end of the R154 still have about an inch or so of separation. Is a small gap supposed to be normal? The rear transmission seal is in there as it should be.
Old 06-09-13, 09:30 AM
Dawa
Dawa's Avatar
is the number of splines the same for either transmission? (idk, so if it were me id count.)
and resistance IF any at all, should be minimum.
Old 06-09-13, 05:29 PM
KahnBB6
KahnBB6's Avatar
ProperD, I looked up the input shaft sizes and it's not just splines. It looks like the R154 shafts are larger in diameter. I did get mine to fit in with minimal resistance after some more thorough wire brush cleaning, brake cleaner and a little bit of motor oil coating the splines at both ends.
It fits in, although there is a small gap where the two collars don't fully meet up. I don't know if this is normal or not but the driveshaft definitely is in there when inserted now.
Old 06-09-13, 05:43 PM
soarer479
soarer479's Avatar
yes a small amount of gap is fine and needed to be able to slip the DS in or out while in the vehicle.
Old 06-11-13, 09:47 AM
Ali SC3
Ali SC3's Avatar
yeah it allows for movement and flex, the W series and R series are like that for our cars.
Old 06-11-13, 02:46 PM
KahnBB6
KahnBB6's Avatar
That's good to hear, guys, thanks! I was concerned at first. So long as it's part of the design.
2JTsc300
06-10-12 07:46 AM
VileFCboy
04-11-12 07:54 PM
SH_JZZ30
02-16-09 09:50 AM
DKNY0331
01-28-08 03:25 PM
soardrft
SC400 / 300 Classifieds
09-13-05 05:53 PM
Quick Reply: How easily should a driveshaft insert into the rear of the transmission?
