bc 264 install in 1jz
Old 06-07-13, 02:10 AM
1jztim
1jztim's Avatar
Default bc 264 install in 1jz
hi i have installed my new cams but my fuelling was very very rich on idle 13.0 afr's
i dont have any cam degree set up tool so can only go by the adjustable verniers for timing set up.
who else has put these in and what cam timing was it set to for as close to stock running as possible ie they werre degree'd and what was the settings on the cam gears, there is a noticable lope on these so not totally sure the cams are set happy, all the timing marks are at zero and have not changed or slipped, it goes well but i would like to get the idle and fuelling smooth, it is single turbo'd with a sard analyse ecu 440's and lot of other changes, everything was factory smooth before the cam install and there is no code on the ecu.
in short 1jz with 264 cams but would like to check the cam wheel timing marks with someone who has these dialed in and see what +- they were set on
thanks
Uhhhsc300
03-29-13 06:13 PM
96sc
01-28-09 10:35 AM
happypanda
04-30-06 10:56 AM
Quick Reply: bc 264 install in 1jz
