92 sc400 w58 no crank/no start. NSS wiring?
Old 05-13-13, 03:19 PM
dhhd
dhhd's Avatar
Default 92 sc400 w58 no crank/no start. NSS wiring?
Hey CL, I am trying to wrap up my w58 swap in my 1992 sc400 for this weekends drift event. I have a no crank no start condition in my car after the swap. I can almost guarantee that the vehicle is looking for the Park or Neutral signal to start the car but isnt seeing it. I checked Red Phoenix's Ultimate W58 thread but his pics are no longer posted... If anyone has info on this, or the pinouts of the connectors and their functions I would extemely appreciate it. I am working so hard to get this done for this weekends event! Thanks in advance!
Old 05-14-13, 08:15 AM
dhhd
dhhd's Avatar
I tried jumping the two green wires on the auto trans range sensor connector from a post that said it would cure the no start. Still no go... Nobody has any info on here??? Hard to believe since there are several manual swapped sc400's on here... :/ Come on fellas please help
Old 05-14-13, 09:46 AM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
We need to start making PDFs of these threads for the SC community for posterity :/ I haven't done that conversion so i can't help you, sorry. The NSS would have been my guess, too.
Old 05-14-13, 09:58 AM
fried_rice
fried_rice's Avatar
https://www.clublexus.com/forums/per...with-pics.html
Old 05-14-13, 10:50 AM
sucessr1
sucessr1's Avatar
Lmaooo fried_rice
Old 05-14-13, 12:27 PM
Ali SC3
Ali SC3's Avatar
Thats the method I have seen the most on here and there was another way jumping wires on the gear selector harness or something like that.
I always wondered if you could just ground the nss pin at the ecu? Haven't seen anyone mention that but after looking at the schematics that may be worth a try but almost seems too simple to work.
Old 05-15-13, 01:44 PM
dhhd
dhhd's Avatar
Ok great thanks. I wasn't sure if the 1jz write up would be applicable to my 1uz but it looks like it will be fine. I'm going to give this a try. Thanks!
Old 05-16-13, 04:27 PM
nurvcom
nurvcom's Avatar
check your theft ecu under dash by steering wheel ( mine was fryed and once i replaced it Bam started
Old 05-16-13, 07:29 PM
JesLet
JesLet's Avatar
Are you sure its the 2 fattest wire on the biggest grey plug from Auto trans?
osomegaSC
01-15-17 05:53 AM
chowda
09-20-15 01:45 PM
k7q
21
09-26-13 07:23 PM
DONT SLEEP
13
07-10-10 07:11 AM
captainsc
SC- 1st Gen (1992-2000)
37
02-22-10 10:19 PM
Quick Reply: 92 sc400 w58 no crank/no start. NSS wiring?
