Need help with gated shifter conversion
Old 04-10-13, 06:58 PM
TheRonTom3
TheRonTom3's Avatar
Default Need help with gated shifter conversion
Ok so I got all of my wiring done and everything mechanically installed and for the life of me I can't get the gear slections to line up. I have tried the one inch shorter shift linkage and just the stock length shift linkage I either can't get the car into park or I cant get low to be actual low.
My only guess is I have a car with p r n d 2 l and my gated shifter mechanism has p r n d-4 3 2-l but shouldnt that still work as 3 would be 2 and 2l would be low
Old 04-10-13, 07:28 PM
1WILLY1
1WILLY1's Avatar
ive always wondered the same thing,,u have two extra gears on the gated shifter , how do they line up
Old 04-10-13, 07:58 PM
TheRonTom3
TheRonTom3's Avatar
Pretty sure it was a common snese thing I screwed up on but all the conversions I have seen seem to use the p r n 4-d 3 2-l shifters but if my old shifter was prnd32l then it should have only made sense to get the same
Old 04-10-13, 08:05 PM
1WILLY1
1WILLY1's Avatar
well they recomend to get the 4321 so u can still keep the overdrive by wiring it into the 4-d
this is the reasoon i never bought one yet because im sure i was gonna run into these issues.
Old 04-10-13, 10:39 PM
account2x
account2x's Avatar
Your shifter says D (5), 4, 3, 2, L but your automatic transmission doesn't have 5 gears. Because of placement your D remains the same but when you select 4 you are actually in 3rd (assuming you wired it right) and 3 becomes 2, 2 becomes L, so L on the shifter has nothing left to map too. If you want perfect labeling you'll need to source a SC300 gated shifter assembly.
Old 04-11-13, 05:48 AM
TheRonTom3
TheRonTom3's Avatar
Ahh See nobody ever said that in any of the write ups. So I did have it hooked up and operating properly last night.
can anyone confirm if overdrive would still work the same way on the SC300 shift? If that install work 100% correctly I would be inclined to do that
Old 04-11-13, 06:48 AM
account2x
account2x's Avatar
If you wired it up correctly D remains D. When you go into 4th on the shifter O/D OFF should turn on.
FYI I'm selling a sc300 gated shifter with linkage.
Old 04-11-13, 06:56 AM
TheRonTom3
TheRonTom3's Avatar
yeah my 4 turned O/D off and D turned it back on
I was talking about on the SC300 gated shifter would 3 remain O/D off and D be O/D on
Old 04-11-13, 05:40 PM
crenfro
crenfro's Avatar
Ok I know this isn't really the point of the thread by whats the point in doin this conversion?
Why is the gated shifter so much better?
LTSC
03-02-13 05:44 PM
Prowler217
SC- 1st Gen (1992-2000)
01-28-09 07:17 PM
romeo291
28
11-10-08 12:32 PM
FlyLexus
02-01-03 07:38 AM
Quick Reply: Need help with gated shifter conversion
